Need help for my B18c1
I need help im not gettting fuel into my fuel line and into my engine i think it could be my fuel pump or my fuel filter can you gimme your expertise on it?
and could i get prices for
Fuel filter ?
Fuel Pump?
or other prices on what you think it could be
Fuel filter ?
Fuel Pump?
Re: Need help for my B18c1
turn key to where it almost starts but dont started see if you can hear pump prime this way you know if its still working. fuel pump should come on second turn on the ignition before start, check for blow fuses and relays.
What do you mean by prime?
cause i only hear the engine turning and i can see my belts move, coolant bubble lol seems like its the fuel pump
little bizzzz noise from the fuel pump, dont crank ignition just turn key to the second click before start. its hard to explain you have to sit in the car count the key turn before starting it
you need to list what car and who hook up motor will help more
1 Post
Turn the key to the 2nd point "JUST BEFORE" the starting point and you should here a click. If you here the click,the relay is working. Have a friend go to the back of the car and you do the same thing with turning the key to the 2nd point and see if you're friend hears the pump. If there's no sound,the pump is bad. Also check all under hood and cabin fuses.
SO i checked it out and i here a buzz at the middle of the car underneath, and it sounds like a little transformer or like a light version of a battery dying when you try to turn it on
1 Post
Sounds like the pump is working but not priming the lines. Have you checked to see if gas is coming out just before the fuel filter? It might just be clogged. Or the pump could be stuck and what you're hearing is the buzz from it trying to turn.
oh alright welll i unpluged the fuel line connected to the fuel adapter? lol and i sucked on it while trying to start it and there was nothing coming out at all
1 Post
lol just don't suck up gas. If you do, try 91 octane Did that one time and swallowed some and got the high of my life..lol But back on topic,the pump must be bad.
That walbro should do just the trick...And 91 LS nice work, you were all over this one
OP if you need help installing this pump, I can help for a small fee...I stay in South Gate/Downey area, not to far from the 626.
