Maintenance Required Light on 94 integra
Old 12-14-2008, 02:39 PM
BadKid's Avatar
Default Maintenance Required Light on 94 integra
hey i got a 94 integra stock LS, when i bought it it flashed the Maint Req'd light 11 times i think when i started it, now it just stays on, i havnt done an oil change in a bit, is this the problem, thanks
Old 12-14-2008, 02:42 PM
bonstokLS's Avatar
The ML will come on normally as mileage increases. It is just there to remind you have maintenance services done. If the CEL comes on..I would look into it further..
Old 12-14-2008, 03:26 PM
slammedexv's Avatar
So how is it turned off? Mine is on as well.
Old 12-14-2008, 03:57 PM
Spoolbeast's Avatar
under the panel on the driver side is a box with a green button turn car on and just hold the button down til it turns off
Old 12-14-2008, 06:12 PM
StokelesS_g2's Avatar
LoL, read the little Integra manual people.
It should of came with your car, if not find one, or download the Helms manual.
Old 12-14-2008, 06:33 PM
BEATurBOYS's Avatar
both are right..theres a box with a button under the driver dash...just push and hold while key is on and itll go off....mine did and never turned back on...
MOTOR ALL DATA! YEAH...BEST MANUAL EVER...
Old 12-14-2008, 09:26 PM
BadKid's Avatar
wow thanks alot guys, but just one quesition, where is this box with the green button ??!
Old 12-14-2008, 09:32 PM
WTF?!
Go sit in your car, pretend you're gonna hot wire your car, feel under the plastic panels by your knees, you feel a box, you feel a square button. You got it!
Turn your key to the on position now, and press and hold the button until your maintenance light goes off.
Enjoy, it'll be back on in 3,000 miles or something like that.
Old 12-15-2008, 02:47 AM
PatrickGSR94's Avatar
It starts flashing every 7,500 miles.
Old 12-15-2008, 07:12 AM
4banger1986's Avatar
there is a little green button under the drivers side dash like patrickgsr said it flashes every 7500 miles
Old 12-15-2008, 07:38 AM
tweek_boii's Avatar
quit playing halo and do your oil change !
Old 12-15-2008, 08:42 PM
BEATurBOYS's Avatar
cheeeeeepono.......................
Old 06-27-2009, 09:59 PM
FatalNickle's Avatar
Default Re: Maintenance Required Light on 94 integra
I have a 1994 Integra RS with a B18B1. My Reset button was right under the ignition, and it was a blue button, square. really easy to find. Had to hold it for about 6 seconds, havnt seen my Maint light on since. Hope this helps for people confused with the green button.
Old 08-15-2009, 10:41 AM
BEATurBOYS's Avatar
this is a good one..cause not all are green..mine is a red button but black box...
Old 09-03-2009, 07:04 PM
Marcos Barrios's Avatar
hay guys mine come on while driving
but it's only on while i'm hitting bumps on the road
but if the road is smooth
then theres no light?
Old 09-06-2009, 10:15 AM
Thats kinda strange if it comes on ONLY while driving and hitting bumps. Might have a shorting wire somewhere + maintenance time.
Old 09-06-2009, 12:21 PM
sixfourkiller's Avatar
X2 its not a bit deal its just to remind u to do maintenance
Old 09-07-2009, 02:07 AM
jdmnic91's Avatar
my button is blue!!!
Lilojames
10-25-2016 06:31 PM
superhatchbackbros
05-06-2010 12:52 PM
dtrtw
02-19-2005 08:36 PM
jmcfkya
09-13-2003 08:31 AM
social_control
08-09-2003 07:52 PM
Quick Reply: Maintenance Required Light on 94 integra
