Need help...my gsr is vibrating when i start it up then turns off...
Old 11-14-2008, 10:37 AM
john0086's Avatar
Default Need help...my gsr is vibrating when i start it up then turns off...
I started up my car 2day and the motor started idling wierd...it was shaking n then it turned off...i turned it back on and it kept doin it but when i gave it gas it wouldnt accelerate steady as it should.....the motor was shaking while i accelerated
Old 11-14-2008, 12:34 PM
twentyhurtz's Avatar
Default Re: Need help...my gsr is vibrating when i start it up then turns off... (john0086)
look for broken stuff, broken motor mount? have you given it a visual inspection?
Old 11-14-2008, 04:44 PM
bigkvn77's Avatar
Default Re: Need help...my gsr is vibrating when i start it up then turns off... (twentyhurtz)
Have you done anything to the vehicle recently. It sounds like it may be ignition related. Possibly leaking tube seals. Pull your wires and plugs. Check on there condition and see if you are having a misfire of some sort. Any cel codes?
Old 11-15-2008, 12:24 PM
john0086's Avatar
thanx for the help guys but i figured out wat it was....my motor is supercharged and i had less than 1/4 gas so thats y it was doin it....since my fuel pump is high perfprmance it requires more gas than usual
jdm91integ
06-27-2014 03:00 PM
Neptronix
11
09-01-2008 12:49 PM
vdawg559
12
05-15-2007 02:15 PM
AllSpedup04
08-16-2005 02:27 PM
DC2point0
13
07-24-2005 06:02 PM
Quick Reply: Need help...my gsr is vibrating when i start it up then turns off...
