JDM DB9 Integra AWD
#51
Re: JDM DB9 Integra AWD
I'm not sure what year it transitioned, but mine's a 1999 CR-V EX AWD w/ 5speed and it has a B20Z engine.
#52
1) boost remaining 1.6L zc
or
2) try to marry jdm integra Type-R or SiR-G b18c with b20b 5speed awd tranny
First way: i'm afraid of it cause didn't know much bout turbo setups (will have to bother you all for every little step)
Second way: more familiar work for me, but more questions remaining - axles, shafts, cv joints, exhaust connection, harness to ecu and gauges...)
#53
I believe the JDM B20B is the same as the B20Z. Unsure of this, but you can look in www.hmotorsonline.com
I just took a peep under my CR-V. It does have 2 cables coming from the shifter area.
No shift linkage like on my Integra.
Since most Integra's came with B-Series engine. I imagine you would just use Integra front axles.
If you have availibility to a CR-V, that'd probaly be your best bet, get a whole CR-V and start swapping parts over to your Integra.
#54
Ah the cable linkage is most likely due to space constraints with having both the exhaust pipe and the center drive shaft under there. There's probably no room for a solid shift linkage. On CR-V's it may also be due to the height of the engine/tranny relative to the rest of the chassis.
#55
OK, it's usdm engine and therefore unavailable for me. So, i can draw a conclusion that my best directions are
or
or
- front axles would have to be from a CRV.
- front section of the rear shaft off of the transfer case may also have to be from a CRV.
- the exhaust connection may be slightly different, but if you have a sawzall and a welder that shouldn't be a big issue.
- You could probably use the JDM harness from whatever engine you get, although you will most likely have to do a few wiring changes (nothing too major) in order to properly operate VTEC if you go with the B18C.
-Just a random thought...although the car would be way more fun than it is with your engine in it, I am betting that this car is not light by any standards. Due to the extra heft spending the extra $$ for a type R or or SIR-G may not be worth it, as those engines produce much more high end HP, but lack the torque you made need to make this vehicle feel "powerful." In the end a complete CRV 5 speed donor vehicle may be the best way to go if you can get your hands on one with the higher output B20B. There are a few JDM B20Bs that had somewhere in the mid to high 140's in hp and torque, but its hard to tell which is which, and as far as I can tell no one really knows which is which without taking them apart. Good luck whatever way you decide to go with!
#56
#57
#58
WOW! Looked further on catalog:
Integra Xi 4WD - wheel base 2620 mm
CRV 2.0 Performa - wheel base 2620 mm
I believe this means there's no need for making custom center drive shaft?
#59
#60
And as far as the wheelbase...I have always heard that crv and integra share a wheelbase, although I never knew there was an awd integra. Keep Plugging!
#61
finally!!!!!!
the whole DB squad has waited for the elusive 4wd integra to be featured like this.
please visit our thread. we've been waiting many years.
thanks for sharing the pictures of your rare car.
https://honda-tech.com/forums/group-threads-123/db-squad-teggers-2-extra-doors-1203330/
#62
Maybe they mean dry weight - with only driver and full tank? My only guess on this.
#63
I doubt the GS-R motor weighs 200lbs more than that SOHC engine w/ a rear differential and all.
Maybe it's just because of all the extra reinforcement weight crap they add to make our USDM cars safer.
(DOT approve crap)
(DOT approve crap)
#66
sick car. if you do the full b20 swap im guessing youd need b-series integra front axles because arent crv axles the same size as jdm itr axles? 36mm at the splines while everything else is 32mm? keep us posted this is very interesting.
#67
U must be right. Although integra & crv share the wheel base, track width of crv is much wider, so crv shafts will have excess length. And what about b18 powered integra shafts length? Will they mate b20b trans & DB chassis?
#69
i think itd be best to boost it. you can easily make 180 whp and i think that the drivetrain will hold that amount of power just fine. tuning is something that you can read about and do yourself if you have the proper equipment.
#70
hi nice car, i own 2 1993 civic eh1 (awd dohc zc and sohc zc)
i gave bisimoto a call asked about a B2D kit, said it would be out this year.
I wouldnt want to go all out and modify the whole car, just a b16 on the sohc eh1 would be nice to help me climb a few roads when i travel. Not really sure on what you have in mind for your car, but if you need contact info for the B2D kit let me know
#71
another issue might be the trans mount. if a b20 trans can take a regular b-series mount from an integra you should be all good
#72
P.S. Please guys make a discount for my english, i'm not english-speaking, just a school lessons & one visit to alaska. I'm from Russia, so i don't know much about USDM trims too, only JDM ones were in my life.
#73
not sure if the crv is wider but i meant the size of the axle splines (the ones that go into the hub) MIGHT be bigger. im not 100% on this i just heard this awhile ago and just thought id bring it up.
I understood the spline issue, so i asked a question about b-series integra shafts & axles. I think it would be easier to install a complete integra shaft/axle setup than make a custom.
#74
Can anyone advice a site to read about this proper equipment? As i see it right, it's d.i.y. work? Or there's a need of special technicians?
#75
Can anyone advice a site to read about this proper equipment? As i see it right, it's d.i.y. work? Or there's a need of very special technicians?
