JDM DB9 Integra AWD
#26
Re: JDM DB9 Integra AWD
[QUOTE=majinsoftware;36891962]You just have to remember Honda AWD isnt real AWD, It only puts 5% of the power to the rear. And they start breaking parts at the 250HP mark.
QUOTE]
you are very missinformed on all three points but thanks for talking about something you know nothing about.
QUOTE]
#27
I don't know for sure, but what about using the 5 speed transmission out of the CRV? I know your car is not hydraulic, but since the firewall probably has a spot for a clutch master cylinder, I would guess it could be converted. This would allow the retention of your AWD and the addition of a B series engine. I believe that the CRV transmission does have a cable linkage however, which could make things even more interesting. I never knew this car existed, but I want one...
#28
And I don't understand this: if rears have max 5% of torque, then how my car's rear wheels spin the car around the front? If front wheels have 95% of power then the car MUST act as FWD. Correct me or i'll break my brain soon, i never discussed hondas with anybody, and you guys know very much about how the things work.
I just found this diagram of 96-up dps 4wd, pic is small but all elements are visible.
#29
#30
So your car has a hydraulic clutch, but a cable linkage then? I was confused by one of your posts up top that said your tranny was a hydraulic, cable type S22 model. If it does have a hydraulic clutch and a cable linkage, I would have to believe that a CRV transmission would fit, thereby allowing the use of a B series engine. Again, I don't have much knowledge regarding your car, because I have never even heard of one, but knowing how honda tends to interchange parts among models, I would look towards the CRV. Good luck!
#32
Forget the LS engine, use the entire CR-V engine and trans. AWD B20Z in a car ftw.
Oh, and yes the CR-V trans will bolt up to an LS engine.
#33
I launch my car on dry hot pavment on the rev limiter (7800) and have never broke anything, car makes about 200 whp and all parts are high millage. There is another awd hatch on here with 400 whp and hasn't brake anything but its first motor.
#34
So, YES, i had to say: my car has hydraulic clutch and cable shift linkage
#35
And argue with those who claimed weak honda awd drivetrain
#36
#37
Have you ever seen the rear CV shafts on an AWD CR-V? They look like pencils. While the AWD Integra drivetrain may be able to handle a stock B20 engine from a CR-V, I wouldn't expect it to handle much more than that.
#38
I know b18c1 (Spec 98) is not bad engine, what do you call it? we call em 'redhead' (sometimes when reading the threads in american forums can't understand the tech slang, sorry.)
Does CRV b20b gearbox need any custom mounts (& custom shift linkage from gear lever) for mounting in teg?
#39
If someone can help me to understand how the things work, ask for pics. I can't make em immediately, but I'll try as soon as possible.
Yeah i saw them, they are much like teg's. But I think front shafts need to be stronger cause they got much more loads while steering/hard cornering when all car wheight is on them. when i had the idea to put rear stabilizer (sway?) bar in my teg i looked at the crv setup. Unfortunately i don't have much space above dps diff unit like crv has.
#40
#41
BTW look at rer lca setup - it's like usdm type-r's, i faced that searching tokico shocks for the car, their bottom end is bolt thru, not fork. The rest of suspension is interchangeable with usdm, except harder stock awd springs.
#42
I owned a 1999 Honda CRV with a 5 speed and it did in fact have a cable linkage paired with a hydraulic clutch. To my knowledge the CRV is the only B series transmission with a cable linkage, and a hydraulic clutch. The 5 speed wagovan or whatever may have had a cable linkage trans. hooked up to the D16A6 that came in those creatures, but I am sure it also hade a cable clutch as well.
#43
Please explain what means for LS? base model b18?
All Tegs made for the U.S. come with DOHC engines.
So swapping one in place of yours shouldn't be no problem.
We weren't blessed with the nice JDM front ends or AWD platforms.
As for certain mounts and levers and what not, we're hoping you could tell us, since we all aren't lucky enough to have a AWD Integra.
I gotta look under my CR-V to see what cables you guys are talking about? The way it drives and shifts, I figured it had a shift linkage just like any other Honda vehicle.
#44
Maybe somebody knows is there any difference in b20b & b18c gearbox mounts or not? Keeping in mind honda's cross-platforming i won't be surprised if these gearboxes have same cases. My trans and the one from FWD zc integra look alike.
#45
Any B series can bolt up to a crv(B20B) transmission yes. I think you will find that your car is an integracrv, meaning an integra body on a crv platform...I am sure there are differences, but you should be able to use many of the parts from the CRV. I still want your car...
#46
#47
Any B series can bolt up to a crv(B20B) transmission yes. I think you will find that your car is an "integracrv," meaning an integra body on a crv platform...I am sure there are differences, but you should be able to use many of the parts from the CRV. I still want your car...
#48
#49
#50
I requested a short story for a title.
very jealous, that is a sick car. i keep hearing about there bein alot of jdm cars and what not up in canada ill have to make a trip its only about 3 hours.
i think customs would kill me tho
