ITR rear seat fitment in a 99 GSR....
okay, so i just got a clean set of JDM ITR rear seats, and i went to put the bottem bench part in and the plastic mounting holes don't match up with the metal seat bracket. and the same thing happend with my 98' GSr cloth seats... why arent the bracks lineing up? help please, thanks
Re: ITR rear seat fitment in a 99 GSR.... (peshte)
they should line up perfectly, are you sure the little metal hooks are in the holders properly?
and how far is the upper metal braket off?
pics would definetly help
Re: ITR rear seat fitment in a 99 GSR.... (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">JDM ITR rear cushion brackets didn't line up either in my old 00 GSR. I just mounted the rear bracket only and it was fine. It definitely did not go anywhere.</TD></TR></TABLE>
did u cut off the 2 front brackets? to make it sit flush? thanks/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peshte »</TD></TR><TR><TD CLASS="quote">
did u cut off the 2 front brackets? to make it sit flush? thanks/</TD></TR></TABLE>
I didn't cut the brackets off. If I can remember correctly, it sat fine or close to flush. I had people sit in the back and they didn't complain. It's been like 3 years since I had the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peshte »</TD></TR><TR><TD CLASS="quote">weird, i have a big black brace that goes across the place where u put the seats, and they are spaced too far appart...</TD></TR></TABLE>
Pics?
Pics?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">So you can't put on the backrests either?</TD></TR></TABLE>
like, the 2 metal "U" shaped things wont aline with the white plactic hole. its too far apart to fit in ..
like, the 2 metal "U" shaped things wont aline with the white plactic hole. its too far apart to fit in ..</TD></TR></TABLE>
But this is your cushion part. The backrest should fit without any problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">I mean, it should sit fine the way it is. If you are really ****, you can cut the brackets off or trade for USDM ITR rear cushions (although you might not like the tray).</TD></TR></TABLE>
not just the tray, the ITR seats are Suade and have red stiching, i'll just get an LS seat mount bracket, they have the seat mounts closer together i think.
not just the tray, the ITR seats are Suade and have red stiching, i'll just get an LS seat mount bracket, they have the seat mounts closer together i think.</TD></TR></TABLE>
And so are the USDM ITR seats.
I still say keep trying. They should fit without any problems and should not require any type of modification. Then again, if you have any pics that would help too.
someone told me that the 96-97 rear seats are diff then the 98 and up cause the bottom wont fit perfectly? i own a 95 RS and was thinking about gettin some JDM ITRS and tahts what somebody told me..
Re: ITR rear seat fitment in a 99 GSR.... (JDM DC4 Jesse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM DC4 Jesse »</TD></TR><TR><TD CLASS="quote">someone told me that the 96-97 rear seats are diff then the 98 and up cause the bottom wont fit perfectly? i own a 95 RS and was thinking about gettin some JDM ITRS and tahts what somebody told me..</TD></TR></TABLE>
You know...I remember hearing the same. If that is true, then I guess the jdm rears I got were from similar chassis and year(s). And, that would explain why the OP is having such a hard time trying to make his set fit.....
Re: ITR rear seat fitment in a 99 GSR.... (Naruto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naruto »</TD></TR><TR><TD CLASS="quote">
You know...I remember hearing the same. If that is true, then I guess the jdm rears I got were from similar chassis and year(s). And, that would explain why the OP is having such a hard time trying to make his set fit.....</TD></TR></TABLE>
hmm, that would solve everything. i have a 99 GS-R, and 94-97 ITR rear seats. should i get the 94-97 seat bracket?...
hmm, that would solve everything. i have a 99 GS-R, and 94-97 ITR rear seats. should i get the 94-97 seat bracket?...</TD></TR></TABLE>
I don't think there is a specific "seat bracket" you can get. Though...if it is possible for you to "remove" the alcantra skin of the seat and transplant it over to your stock seats your car came with........that may work better than going out to "buy" something you may not need.
I don't think there is a specific "seat bracket" you can get. Though...if it is possible for you to "remove" the alcantra skin of the seat and transplant it over to your stock seats your car came with........that may work better than going out to "buy" something you may not need. </TD></TR></TABLE>
This might not work because of the tray
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peshte »</TD></TR><TR><TD CLASS="quote">hmm, that would solve everything. i have a 99 GS-R, and 94-97 ITR rear seats. should i get the 94-97 seat bracket?...</TD></TR></TABLE>
i want 94-97 rear seats... im afraid when i buy some they might be 98 and up.
this is very simple.....94-97 integra have no reenforcement bar that goes from one side of the car to the other!!!
You can put your type-r seats witch are from a 96-97 type-r and put them in your 99- up integra by removing that reenforcement....but I dont recomend it!! Get seats from 98- up type-r
I got a olders Rs and installed my 01 usdm ITR in my car, top fit fine but bottom wasn't secure. like.... if it wasn't for the seat belts coming through the hole, peoplecan just pull my bench out. I hear this happends to alot of people.
