Integra's 7 best upgrades
Just wondering about the experties opinion. what do you guys think are Integra's 7 best upgrades, from best to least best???
Re: Integra's 7 best upgrades (LILSOWEK)
1. Turbo
2. Supercharger
3. Nitrous
4. Cams (internals)
5. Suspension
6. Exhaust (headers, cat, muffler)
7. Intake
Just an opinion. Maybe way off. I guess it really depends on what your overall goal would be (speed, 1/4 mile, looks etc).
2. Supercharger
3. Nitrous
4. Cams (internals)
5. Suspension
7. Intake
Semper Fidelis
Re: (LILSOWEK)
I don't know about greatest to least. But I would have to say
Intake (weather it is SRI, CAI, ITB's)
header (you get what you pay for)
exaust
cams
pistons
transmission
TUNNING!!!
exaust
cams
pistons
transmission
TUNNING!!!
yeah i have a b18c1 bored to 81.5mm with balanced 95mm crank, custom rods, wiseco 11.5:1 comp and stock gsr head. act 6 spuck clutch, 11.5lb flywheel. ls tranny.
Daisy... Daisy...
Factoring both effect and cost:
1) Tires (They are the only part of the car designed to touch the road.)
2) LSD (It doesn't matter how much power you are making if you cannot get traction. The main effect of an LSD is improved cornering ability.)
3) Suspension (springs, shocks, bushings, sway bars, tower bars)
4) Transmission (Shorter, closer ratios always help. A lighter flywheel is a good upgrade as well.)
5) Brakes (see the 282mm ITR front conversion thread. https://honda-tech.com/zerothread?id=734560 Use the 92-96 prelude VTEC rotors only because they have the correct center bore and can be redrilled without overlapping holes.)
6) Nitrous (Cheap power. Doesn't affect the normal operation of the car.)
7) Engine work or turbo.
Engine work comes last because the chassis should be balanced and optimized before worrying about greater power.
H-T Order of Merit
Re: Integra's 7 best upgrades (Dogginator)
1. Drivers school (HPDE)
2. Drivers school (HPDE)
3. Drivers school (HPDE)
(I think you get the idea)
4. Motor oil (synthetic)
5. Tires
6. Brake fluid
7. Brake pads
5. Tires
6. Brake fluid
7. Brake pads
Re: (LILSOWEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LILSOWEK »</TD></TR><TR><TD CLASS="quote">yeah i have a b18c1 bored to 81.5mm with balanced 95mm crank, custom rods, wiseco 11.5:1 comp and stock gsr head. act 6 spuck clutch, 11.5lb flywheel. ls tranny.</TD></TR></TABLE>
well in your case
1. gsr or si tranny
well in your case
1. gsr or si tranny
Semper Fidelis
Re: (CW_98gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW_98gsr »</TD></TR><TR><TD CLASS="quote">
well in your case
1. gsr or si tranny</TD></TR></TABLE>
If he already has a b18c1 then I would assume that he has a gsr tranny. If you are going to upgrade trannys I would reccomend ITR (for LSD) or SI (B16 shorter gears)
well in your case
Daisy... Daisy...
Re: (LILSOWEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LILSOWEK »</TD></TR><TR><TD CLASS="quote">have any of you guys upgraded to accord v6 calipers??? about how much did it cost</TD></TR></TABLE>
Yes. Follow the link in my post above. The Accord V6 and ITR front calipers are the same.
i did follow the link but it doesnt let you post anymore, i was wondering if you really need Stoptech Brake Lines, and i was wondering where you got the calipers for $40??
Daisy... Daisy...
Re: (LILSOWEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LILSOWEK »</TD></TR><TR><TD CLASS="quote">i did follow the link but it doesnt let you post anymore, i was wondering if you really need Stoptech Brake Lines, and i was wondering where you got the calipers for $40??</TD></TR></TABLE>
Why can't you post there? The thread is not locked?
The calipers came from a salvage yard online. http://www.car-part.com
The brake lines are not necessary.
Please use the 92-96 Prelude VTEC calipers if you choose this option. The 5x114.3mm ITR rotors have a 70mm centerbore instead of a 64mm bore. You will also ovelap at least one luge hole by redrilling a 5x114.3mm pattern to a 4x100mm pattern.
Daisy... Daisy...
Re: (LILSOWEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LILSOWEK »</TD></TR><TR><TD CLASS="quote">basically use vtec prelude calipers with brembo rotors for preludes.</TD></TR></TABLE>
Calipers from a Prelude VTEC, the ITR, and some Accord V6s will work. The rotors need to be from a 92-96 Prelude VTEC with the 4x114.3mm lug pattern.
Daisy... Daisy...
Re: (gsrbeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrbeast »</TD></TR><TR><TD CLASS="quote">is the gsr tranny hydro or lsd?</TD></TR></TABLE>
http://www.ff-squad.com/tech/temp/Bgears.htm
Re: (Dogginator)
A non centrifugal supercharger is dumb on a high revving honda.
A plan i like to go by is
1. Brakes/wheels/tires
2.Suspension
3. Intake/header exhaust.
2.Suspension
Guess whos bizzack
Re: Integra's 7 best upgrades (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">1. Drivers school (HPDE)
5. Tires
6. Brake fluid
7. Brake pads
YESH!!
5. Tires
6. Brake fluid
7. Brake pads
YESH!!
