ebay halo angel eye light output?
Old 07-16-2012, 09:57 PM
Kennyjai's Avatar
Default ebay halo angel eye light output?
Does anybody have pictures of the output on a wall? i'm not anticipating on putting the full ebay housings on my car, just like to see what the output is like compared to the OEM integra lens cover with lines.
Old 07-17-2012, 12:01 AM
Solster's Avatar
Default Re: ebay halo angel eye light output?
try adding a link to the E-bay HL's your looking at.
Old 07-17-2012, 09:32 AM
Kennyjai's Avatar
i'm talking about these, pretty sure everyone has seen them or at least heard of them before.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=320925771524
as you can see, the lens cover on these doesn't have those lines like the OEM ones do. that being said, with our 11-15 year old lenses, i've already wetsanded and polished them to the best I can and they have that yellow layer on it. not sure if this is why my HID's are green or not but i suspect those minty clear lens to be better.
i have the ZKW-R clear projector lens mod and vvme 6000k.
Old 07-17-2012, 12:50 PM
Solster's Avatar
my friend has a set and they work very well.
now we did mod his as he got a set of HID's for both high and low beams.
the projector lens is designed for halogen bulbs and works well it still works with hid's but if you want it to look better and give you a more Stock look with the HID's you need to change the lens over to the TSX lens it's made for HIDS.
here is the link to get the lenses.
http://www.theretrofitsource.com/pro...roducts_id=135
for the record you only get the lenses not the silver housing behind it
Old 07-17-2012, 04:15 PM
90efb16's Avatar
rice
Old 07-17-2012, 09:47 PM
Kennyjai's Avatar
im talking about the outer plastic lens cover. the clear ones without the lines on the ebay ones. the oem ones has lines that distort the cutoff, but i heard in the slightest bit.
with the new ones off the ebay set, the cutoff should be a little sharper.
don't know why your friend got the tsx projector lenses, the OEM one's are 3" not 2.5". unless the aftermarket ones are 2.5"?
Originally Posted by 90efb16
rice
lol
Old 07-17-2012, 10:26 PM
Solster's Avatar
The TSX lenses are not just a round dome lens they have a cut line in the center the reshapes the light output and gives you a almost flat line across the road and a flood light effect above that it help keep from blining oncoming traffic and you get more light in front of the car where you want it rather then all over the place.
as far as the clear outer housing the light pattern from the Lens will be sharper.
Old 07-17-2012, 10:45 PM
Kennyjai's Avatar
do they fit the OEM projectors though? the projectors are 3.0", how do you fit a 2.5" on there?
riceforlife
Lighting
10
12-23-2007 02:36 PM
sdr glenn
Honda Civic (2001 - 2005)
19
12-02-2007 09:19 AM
Nors
11-17-2006 09:06 PM
GOLDBERG
05-05-2006 07:10 PM
H23vtecEG
06-21-2005 06:05 AM
Quick Reply: ebay halo angel eye light output?
