integra gsr abs light
Old 12-14-2009, 04:15 PM
njmad's Avatar
Default integra gsr abs light
ok i got a 1997 integra gsr and the abs light has been on for a while. what do i need to check what the code is and what is wrong. can i use a OBD II scanner to check the abs light?? i no it can check the check engine light but can it check the abs light ??
Thanks Nick
Old 12-14-2009, 04:27 PM
dstah's Avatar
Default Re: integra gsr abs light
check your sensors, they probably just need to be cleaned
Old 12-15-2009, 01:15 AM
grjr's Avatar
do you hear the ABS motor run when you start the car? check the battery connections for the ABS are not corroded and clean.
Old 12-15-2009, 01:52 PM
njmad's Avatar
thats not the question but thanks anyways. what sensors are you talking about??
but the question is can i use a scaner ???
Old 12-15-2009, 02:10 PM
iH8RICERZ's Avatar
You can check the abs code yourself by jumping your ecu (jumper/paper clip). Not sure where the thread is in here that explains what each blink means....typically, the abs wheels sensors are dirty and they just need cleaning. To answer your question about hooking up a scanner, shouldn't be a problem...
DC206R
10-18-2009 09:26 AM
rhino87
03-24-2009 09:57 PM
mister m 83
01-15-2009 09:36 PM
92LudeSI
05-31-2003 12:51 AM
redteg1
08-18-2001 02:42 PM
Quick Reply: integra gsr abs light
