installed new brakes now it smells HELP
ok so my rotor was really bad i changed it and now it smells like somethings burning is this normal for new brakes/rotor
Re: installed new brakes now it smells HELP (jdmboi86)
Did you replace both rotors in front? Did you replace all 4 pads in front?
You should ALWAYS ALWAYS replace rotors and/or pads on both sides of either the front or rear whenever you do a brake job. Not necessarily both front and rear, but always both sides of whatever end of the car you're working on. And if you're replacing or resurfacing rotors, you have to install new pads because the old pads were worn to match the old rotors. An old pad on a new rotor is NOT good.
yea they are all new pads and rotor but why do my right side only smells like buring
did you lube up all the caliper slide pins w/ high-temp brake grease, and install the little rubber boots back over the slide pins properly when re-installing?
And you did replace BOTH front rotors?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">did you lube up all the caliper slide pins w/ high-temp brake grease, and install the little rubber boots back over the slide pins properly when re-installing?
And you did replace BOTH front rotors?</TD></TR></TABLE>
yea all new fronts greased all correct
i dunno, the piston could be siezed up in the bore or something. Might need to do a caliper rebuild, or just replace the caliper.
or can one side is clapping harder cause when i looked/compared both rotors one side show use and the other is like new wtf
Re: installed new brakes now it smells HELP (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">i dunno, the piston could be siezed up in the bore or something. Might need to do a caliper rebuild, or just replace the caliper.</TD></TR></TABLE>
is there any way to get unsiezed
how long ago was this? If just recently and you can already tell the difference in pad thickness between one side and the other, then that one side w/ the thinner pads is most definitely siezed up.
*edit* wait nevermind you meant rotor face is showing use, yeah that means the caliper is not sliding properly, probably the piston siezed up or frozen in place. That's probably why the old rotor was so bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">how long ago was this? If just recently and you can already tell the difference in pad thickness between one side and the other, then that one side w/ the thinner pads is most definitely siezed up.</TD></TR></TABLE>
like 2 days ago i can tell cause the left side still have the criss-cross marks and the rite dont noe more
oh crap you noe any good replacement like a upgrade to gsr or something
all non-ITR Integras from the same generation use the same brakes, at least on G3, should be the same for G2 also.
hott-nix
04-04-2005 01:33 PM
