Injectors spitting gas??
Old 07-20-2008, 09:38 PM
kaspa35's Avatar
Default Injectors spitting gas??
Ok so i installed my new skunk 2 intake mani today on my 1990 teg ls.....and when i turn the ignition and the fuel pump kicks on the injectors spit gas out of the top of them (near the fuel rail)....any ideas why? the o-rings on the bottom where they snap in to the manifold are brand new...but the gas is out of the top...any help guys?? thanks
Old 07-20-2008, 09:50 PM
jturbo8316's Avatar
Default Re: Injectors spitting gas?? (kaspa35)
Sounds like the O rings by the fuel rail are bad.
Old 07-20-2008, 10:01 PM
kaspa35's Avatar
Default Re: Injectors spitting gas?? (jturbo8316)
i checked them and they looked ok...anything else anyone can think of to check...
Old 07-20-2008, 10:41 PM
kaspa35's Avatar
ttt
Old 07-21-2008, 04:36 AM
na+b18c_hatch's Avatar
make sure the injectors are seated correctly on the intake manifold. if they are tweaked just a little bit they'll leak.
i never had any problems with my skunk2 manifold
Old 07-21-2008, 05:23 AM
vladd's Avatar
wrong fuel rail (holes too big)? worn o-rings? improper installation? there's not that many possibilities.
Old 07-21-2008, 06:43 AM
steveharrmr23's Avatar
Default Re: Injectors spitting gas?? (vladd)
i would go with worn o rings as you may have looked at them and they may look fine they can be worn out from getting warm the cooling will cause the to ware but look fine as in no cracks in the ring but it will not have the elasticty it should thus not makeing a good seal
Old 07-21-2008, 08:06 AM
kaspa35's Avatar
Default Re: Injectors spitting gas?? (steveharrmr23)
thanks everyone illl try that today...but that seems weird....cuz i had no prolbems before...then i installed new im...and now spitting gas??? could i have ruined the o-rings while doing the change??
Old 07-21-2008, 08:40 AM
kaspa35's Avatar
ttt.......injectores wherent taken off fuel rail when putting in the im.....
Old 07-21-2008, 10:27 AM
not be a smart *** or anything then how do you know the o rings are good up there if you did not take them off the rail also just because you did not remove them does not mean they did not wiggle any
Old 07-21-2008, 11:32 AM
kaspa35's Avatar
but gas spews out of all 4 now....and before i messed with anything there where all good....you know how you clip them down into the im...well the gas comes out of the other side of the injetors....sorry guys im just lookin for the problem...i wanna drive my teg
Old 07-24-2008, 02:36 PM
i know how you feel i am rebuilding the head on mine
CRXz6
06-29-2012 02:55 PM
Ronin150
07-18-2005 01:40 PM
locoSIR20
02-09-2005 04:09 PM
I Want An Si
12-27-2003 07:51 PM
CRX Si
03-11-2003 03:50 PM
Quick Reply: Injectors spitting gas??
