I just put 750cc rcs injectors and problems?
Old 04-27-2006, 03:42 PM
B18ceed's Avatar
Default I just put 750cc rcs injectors and problems?
i have the car tuned on hondata when the new injectors went in and eversince all ive had is problems, it was tuned with iridium2668 bkreix8 and they keep fouling, i parked on a slight incline and car wouldnt start? im thinking theyre leaking but how do tell? is there anything i can do to test...thanks
Old 04-27-2006, 03:44 PM
Daisy... Daisy...
Dogginator's Avatar
Default Re: I just put 750cc rcs injectors and problems? (B18ceed)
750cc injectors? What is your setup? What is your fuel pressure?
Old 04-27-2006, 04:39 PM
B18ceed's Avatar
Default Re: I just put 750cc rcs injectors and problems? (Dogginator)
2.5charge piping t04b tial38mmwg drag2mani stock ignition 8degrees timing 750rc holley pump 40-45fp just had bottem end built iridium 2668 plugs
Old 04-27-2006, 05:00 PM
StolenTeg's Avatar
Umm you werent tuned with the 750 on? sound like running pig rich and fouling them.
Old 04-27-2006, 05:46 PM
red_crx's Avatar
Default Re: I just put 750cc rcs injectors and problems? (StolenTeg)
where you tuned with the 750cc's on the car?
Old 04-27-2006, 06:00 PM
kuja's Avatar
Default Re: I just put 750cc rcs injectors and problems? (red_crx)
Yea i can't quite understand whats going on either. If you just slapped in the 750's its deff gonna give you some hassle if you were tuned on something smaller. Thats what it seems, seeing as how your plugs are fouling. Which would happen very quick..
Check around the injectors, where they plug into the fuel rail when you have pressure in the system, you'd know if they were leaking, i'm sure you'd smell it.
Old 04-27-2006, 06:09 PM
B18ceed's Avatar
yes i was tuned with the 750. the tuner said he tunes closed loop not using o2sensor. i put new plugs in today drove the car 4hours came home parked it and wont start 4hours later? theres so m uch fuel not burning up that its blowing out the tailpipe.
bnmm
02-08-2011 05:54 PM
infulleffect
05-04-2006 06:19 PM
cutt
04-25-2006 12:12 AM
Thumper!
05-24-2004 11:49 AM
GSRrR
10-03-2001 03:18 PM
Quick Reply: I just put 750cc rcs injectors and problems?
