Howling and droning noise at about 40mph HELP!!!
Old 05-31-2005, 12:00 PM
spender1326's Avatar
Default Howling and droning noise at about 40mph HELP!!!
Here's the problem.
When coasting or without gas, there is howling or droning noise between 30 to 50 mph. No gas, not corning, just going straight, with clutch disengaged, and without brakes. The noise seems to be coming from the front. However, below 20 no noise, above 60 nothing I can hear, could be wind noise, but a definate decrease in howling/droning noise.
Axles???
I know I have bad axles (ripped boot), but I am not sure that's the problem. I researched, and most on this and other boards have said, clicking or howling noise with vibration "Under Acceralation." I have this problem when coasting. My question is: Could it still be axles if not under accerlation?
Wheel Bearings???
More research points to wheel bearings. But, I jacked up the car and performed the test of trying to shake the wheel. Put one hand on top, other on bottom of wheel and push/pull. Nothing. The wheel is solid. If it's bad wheel bearings, should there not be play in the wheel?
What else can it be???
BTW, i rotated my tires recently and installed a type R rear sway, but that shouldn't create howling droning noise from the front, should it???
Well, I"m stumped guys. Any help is appreciated. Thx in advance.
Old 05-31-2005, 03:08 PM
Default Re: Howling and droning noise at about 40mph HELP!!! (spender1326)
TTT, someone HELPPPPP!!!, pls. thx.
Old 05-31-2005, 03:36 PM
bottlefed13's Avatar
i have some howling in the front right side. it's just my tire. i have uneven tire wear. not sure if you have the same problem. i just took my rim and tire off and looked at it. you can tell if the tire has been worn down unevenly.
Old 05-31-2005, 05:27 PM
calxtreme's Avatar
it could be your tires. Some tread patterns are noisier than others.
EK_MaGz88
03-17-2011 02:32 AM
Mr.Luder
10-16-2007 03:54 PM
Josh.
14
05-30-2005 09:47 PM
Blastek
10-18-2004 08:34 AM
631 Teggy
12-29-2003 07:55 PM
Quick Reply: Howling and droning noise at about 40mph HELP!!!
