how many quarts of oil does your integra take??
Old 06-05-2003, 06:11 PM
scrap1ngsr's Avatar
Default how many quarts of oil does your integra take??
I just did a oil change and my gsr took about 5 quarts of oil to fill, is that normal or too much..(first time doing a oil change myself) thanks...
New User
threatcon13's Avatar
Default Re: how many quarts of oil does your integra take?? (CivicSiR94)
Old 06-05-2003, 06:12 PM
P1mpSlap's Avatar
4.5 puts it right at the 2nd dot on the dipstick.
Old 06-05-2003, 06:21 PM
VTECorona's Avatar
Default Re: (P1mpSlap)
I always use 4 when I do oil changes.
TeamTooQuick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">4.5 puts it right at the 2nd dot on the dipstick.</TD></TR></TABLE>
Old 06-05-2003, 07:04 PM
conesmasher's Avatar
ditto
Old 06-05-2003, 07:14 PM
GirlyGS-R's Avatar
Old 06-05-2003, 07:17 PM
216.226.142.95:27016's Avatar
Default Re: (GirlyGS-R)
4.25 quarts
Old 06-05-2003, 07:33 PM
Aaron M's Avatar
Default Re: (216.226.142.95:27016)
4.5, whats weird is last oil change it took about 4.75
Old 06-05-2003, 07:50 PM
Sportmode's Avatar
4.25 just like it says in the manual
Old 06-05-2003, 07:52 PM
Regular Series's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiR94 &raquo;</TD></TR><TR><TD CLASS="quote">I just did a oil change and my gsr took about 5 quarts of oil to fill, is that normal or too much..(first time doing a oil change myself) thanks...</TD></TR></TABLE>
Drain the oil to the proper level before you drive again. Too much oil will damage your seals.
Old 06-05-2003, 08:06 PM
Volcom's Avatar
Default Re: how many quarts of oil does your integra take?? (Beelzebozo)
My RS takes alittle less than 4, the oil pan is dented in
Old 06-05-2003, 08:38 PM
GreddyGSR01's Avatar
4 quarts start to finish, but if you have an oil cooler then 5 quarts
Old 06-05-2003, 08:40 PM
Stebo77's Avatar
I think when your pouring in the oil, you have to wait a min for the oil to get to the pan for reading. If your in a hurry and pour and check it, it wouldn't read right and that why you would end up with 5 quarts. My .02¢.
Old 06-05-2003, 08:47 PM
brucek2's Avatar
Default Re: how many quarts of oil does your integra take?? (Stebo77)
i think my friend uses 4-5 quarts... owners manual will tell ya.
Old 06-05-2003, 09:48 PM
King_j's Avatar
Default Re: how many quarts of oil does your integra take?? (brucek2)
i fill it with 4 qt. then i start the car, let it run for like 1 min. then shut it off and check like 5 min later. usually i end up adding like half a qt. or so.
remember, oil will sit in the filter, causing less oil to be in the crankcase.
Old 06-05-2003, 10:12 PM
Nikon!!!
thaiphob's Avatar
Default Re: how many quarts of oil does your integra take?? (King_j)
if you have a Rs, Ls, Gs = 4 qt
if you have a GsR or Hype R = 4.5 qt
Old 06-05-2003, 10:21 PM
Skunk2Steve
Guest
Posts: n/a
Mine takes 4 about every 4 days!! Sounds like a ring problem!!! hahahah
Old 06-06-2003, 01:59 AM
tC_Dragon's Avatar
Default Re: (Skunk2Steve)
i tend to drop in a tiny bit more than 4 qts. and we do about 4.25-4.5 for my roomates gsr.
Old 06-06-2003, 03:02 AM
01-1293's Avatar
Default Re: (pdcdragon)
i fill my Hype R with 4.25 qts...........just as it says in the manual
Old 06-06-2003, 05:11 AM
gsrclan's Avatar
Default Re: (97RedTegGSR)
I always put in 4 qt. 4.25 is the total capacity, but you can't drain all the oil out, so 4 qt is just about right.
Old 06-06-2003, 12:29 PM
scrap1ngsr's Avatar
Default Re: (gsrclan)
thanks
Old 06-06-2003, 12:36 PM
JL 74's Avatar
Default Re: (CivicSiR94)
4.2
Old 06-06-2003, 12:46 PM
fivespeedintegra's Avatar
fill it w/ 4
only drain about 3.75 though
Old 06-06-2003, 01:37 PM
JL 74's Avatar
Default Re: (fivespeedintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fivespeedintegra &raquo;</TD></TR><TR><TD CLASS="quote">fill it w/ 4
only drain about 3.75 though</TD></TR></TABLE>
If you drain it at operating temp and w/filter, most of the oil should have drained out so you must be burning some oil.
Quick Reply: how many quarts of oil does your integra take??
