How to keep Cruise control with aftermarket wheel
Old 01-22-2012, 02:16 PM
jserman's Avatar
Default How to keep Cruise control with aftermarket wheel
Okay this is my first attempt at a DIY so hopefully this helps some people..
This was performed on a 97 Integra DB8.
I have always wanted to do a personal steering wheel but never wanted to give up my cruise control. Well after talking with a good friend of mine on how he did a customers EG we came up with a plan on how to do my integra.
First thing you will need is the windshield wiper control stalk from an integra 2dr that has the rear wiper controls on it.
second you will need the harness on the clock spring that goes from oem cruise control buttons to the clock spring.
basically you will be using the rear wiper controls to turn on the CC...
first you will need the connector that plugs into the bottom of the stalk that goes to the rear wiper controls
it's the one on the bottom it has 5 pins in it
i just cut this connector off as I have a 4 door and don't have a rear wiper
next you have to cut the connector that plugs into the back of the clock spring
you will using this harness you connect everything together
then you need to connect some wires.
The wires should connect like this
connect the GREEN/BLACK wire from the wiper to the LIGHTGREEN/RED wire of the clock spring harness
and the BLUE/BLACK wire from the wiper to the BLUE/GREEN wire of the clock spring harness
after I connected the wires I tucked every together and taped it back up..this is what it looked like done
okay so the harness end of the clock spring plugs into this plug under the dash
and of course the other end plugs into the windshield wiper stalk.
this shows both connectors plugged in
The only thing left to do is button everything up....
to activate the cruise all you have to do if toggle the rear wiper switch to the either the top or buttom wiper fluid control and your good
if you have any questions feel free to contact me with any questions... hope this helps
Quick vid
Old 01-22-2012, 02:33 PM
bryan24207's Avatar
Default Re: How to keep Cruise control with aftermarket wheel
driving to the gas station?? lol..nice steering wheel btw..what hub and quick release are u using
Old 01-22-2012, 02:46 PM
Whiterice-gsr's Avatar
thats awesome, ive been dying without my cruise since i put my wheel in im totally doing that because i deleted my rear wiper anyway so the controls are just doing nothing anyway
Old 01-22-2012, 03:22 PM
jserman's Avatar
NRG short hub and NRG 2.5 Quick release...
I was going to post that anyone that had deleted the rear wiper can do the same thing but not sure if the wiring is identical... let me know how it turns out... I am so excited i got it working....
Old 01-23-2012, 10:47 AM
The Grumpiest
grumblemarc's Avatar
Nice effort but here's what I think is a better DIY. Use the buttons of your choice as long as they're momentary switches.
http://www.d-series.org/forums/diy-f...ket-wheel.html
Old 01-23-2012, 02:59 PM
mouab18c1's Avatar
Pretty cool, I never use CC.
Old 01-23-2012, 03:32 PM
jserman's Avatar
yea I have seen that... but I didn't want some crappy aftermarket buttons in my car i wanted it to look stock...
my buddy one upped that and used a sunroof switch in his EG so it looks OEM.....
and the wiring in the EG is different then in an Integra....
but to each his own
Old 01-25-2012, 01:22 PM
EnjoyTheRideDC2's Avatar
Awesome idea.
Perfect Execution.
Old 05-02-2012, 02:56 PM
Enzo731's Avatar
Thanks for the write-up, great alternative with intuitive thinking. Makes it so clean!
Old 06-23-2012, 12:15 PM
Dynasty21's Avatar
Location: Where We Squeeze 1st N Ask Questions Last, CA, USA
Thank you! Just did this a few minutes ago!
Old 05-10-2016, 01:53 PM
too_cool_3's Avatar
I'm hoping someone with a some electrical knowledge can answer this question. Is it possible to wire up the rear wiper switch to activate RESUME/accel and the SET/decel with the washer on (up) and washer on (down). Or is this impossible because the signal for both (up) and (down) washer on is the same?
masterofphones
04-25-2017 07:49 PM
Ficky
Honda Civic (2001 - 2005)
11-12-2006 10:19 AM
mmmtrbolude93
07-13-2006 07:49 AM
Quick Reply: How to keep Cruise control with aftermarket wheel
