how to install oem itr strut bar in an ls? need help
how can i install an oem itr front strut bar in an ls? do i need itr lca's? if so how do i install the lcas?i want the type r strut bars but when i tried to fit my friends strut bar it wouldnt fit cuz our stud patterns are different..or is this just with my car?
Re: how to install oem itr strut bar in an ls? need help (iwantfastcars)
If you're refering to the bar that goes over the engine bay connected at the shock towers, then it will fit without itr lower control arms. ITR lca's are for the rear suspension. If you have a 94-up ls, I believe you need to remove the grommets on the shock towers and replace them with some nuts, washers, and bolts to bolt on the strut tower bar.
Brad
Brad
Re: how to install oem itr strut bar in an ls? need help (Brad)
Exactly what Brad said, but you have the strut bar and LCA mixed up.
Brad
Brad
Re: how to install oem itr strut bar in an ls? need help (Understeer)
i have a 94 ls, so all i have to do is get four nuts and bolts and remove the rubber covers and bolt it on?
Re: how to install oem itr strut bar in an ls? need help (drewspeed)
not tryna sound like a smart *** or anything..but by doing that will that help stabliize my car struts??? or will it be just for looks?
your car doesn't have struts, it has shocks, and it's a shock tower bar. It helps brace the large unbraced span across the engine bay, but on a car like the Integra w/ double-wishbone suspension, a bar that braces the upper control arm bolts (like Neuspeed's 4-point bar) theoretically should be more effective.
[Modified by PatrickGSR94, 2:09 AM 12/6/2002]
Re: how to install oem itr strut bar in an ls? need help (PatrickGSR94)
shocks? Last time I was at the part store, they were called "struts" for the integra.
Re: how to install oem itr strut bar in an ls? need help (mickey513)
Regardless, the strut/shock bar I put on is the OEM ITR one and I didn't feel a difference, physically or psychologically
