how hard will it be to drop the fuel tank and change the fuel pump
I have a 92 Acura Integra GS. I think my fuel pump is going out, How hard will it be to drop the fuel tank and change the pump? Is there anything i have watch out for? I'm thinking about changing my pump to MSD. Anyone know what to do?
Hype-R Stalker
Re: how hard will it be to drop the fuel tank and change the fuel pump (black_integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_integra »</TD></TR><TR><TD CLASS="quote">so it's under the seat I thought it was in the tank</TD></TR></TABLE>
It is in the tank, which is under the back seat.
Hype-R Stalker
The rear seat, the bottom should only be one piece, and it's in the middle.
Hype-R Stalker
Yes, the slightly round plate, should have 3 phillip head screws in it.
Re: how hard will it be to drop the fuel tank and change the fuel pump (CleanLikeJdm)
Older civics and CR-X's you have to drop the tank to get to the fuel pump
Integras FTW!
Integras FTW!
Re: how hard will it be to drop the fuel tank and change the fuel pump (Spectrum24x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x »</TD></TR><TR><TD CLASS="quote">Older civics and CR-X's you have to drop the tank to get to the fuel pump
Integras FTW!</TD></TR></TABLE>
You have to drop the tank for DA's. Newer integra's it's under the seat. I have the haynes manual sitting in front of me.
Re: how hard will it be to drop the fuel tank and change the fuel pump (93_teg_CT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_teg_CT »</TD></TR><TR><TD CLASS="quote">
You have to drop the tank for DA's. Newer integra's it's under the seat. I have the haynes manual sitting in front of me.</TD></TR></TABLE>
no you dont have to drop the tank on DAs
I have a DA its right under my back seat
Its definitely not under the back seat in a DA. You will have to drop the tank. Its not that hard with someone helping you.
Re: how hard will it be to drop the fuel tank and change the fuel pump (2ndgentegracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x »</TD></TR><TR><TD CLASS="quote">Integras FTW!</TD></TR></TABLE>
more like DC's FTW! ya you will have to drop it.
Re: how hard will it be to drop the fuel tank and change the fuel pump (phoshizzle88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phoshizzle88 »</TD></TR><TR><TD CLASS="quote">you dont need to drop the tank. jus pull up the back seats.</TD></TR></TABLE> YOU ARE WRONG!!! Don't listen to him, he obviously has never performed this procedure before. You will definateley have to drop the tank to change the pump. The cover you're seeing under the back seat is for the fuel level sending unit only!!! all in all, it's a preety straight foward intall. shouldn't take more than 3.5-4 hrs. and that's for a noob, good luck broham!
1 Post
fuel pumps are every easy to change and are under the back seat on 92_ civics and 94+ integras
they are a bitch and a half to change in Ef's and da integras beause you must drop the tank
yes, you will definitely have to drop the tank!
there are 2 bolts that hold the tank up on straps, the hook on the front side of the tank, and have bolts on the back side (towards rear)
you will first have to take off the plastic cover on the driver's side to disconnect the fuel lines before dropping
the biggest problem i had when doing this for my walbro 255 pump was rusty bolts that took a little work to get loose, oh, and get a deep socket
Re: how hard will it be to drop the fuel tank and change the fuel pump (rkrone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9 Purist »</TD></TR><TR><TD CLASS="quote">You will definateley have to drop the tank to change the pump.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndgentegracer »</TD></TR><TR><TD CLASS="quote">Its definitely not under the back seat in a DA. You will have to drop the tank. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoseRPunKx182 »</TD></TR><TR><TD CLASS="quote">yes u do have to drop the tank in a DA. it's not hard, i dropped it myself </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jo_moped »</TD></TR><TR><TD CLASS="quote">i thought that was the pump as well but its not... they are right you do need to drop it </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 »</TD></TR><TR><TD CLASS="quote">they are a bitch and a half to change in Ef's and da integras beause you must drop the tank</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkrone »</TD></TR><TR><TD CLASS="quote">yes, you will definitely have to drop the tank!</TD></TR></TABLE>
Re: how hard will it be to drop the fuel tank and change the fuel pump (jared99)
dont forget to drain most of the gas out or the tank will be heavy as hell and gas will spill all over the place when you pull out the fuel pump.
