How do I check for a bent valve
Old 04-19-2015, 12:07 PM
potatointegra01's Avatar
Default How do I check for a bent valve
I have a b18b and the head is completely off the car. Due to a valve bent noise and clicking also engine shaking. I test the valves using water and no water leaked thru them. Is there any easy way to check for them?
Old 04-19-2015, 12:38 PM
B_Swapped93's Avatar
Default Re: How do I check for a bent valve
You were supposed to do a "leak down" test while the head was still on the car and before that compression. But you just a went an pulled the head cause you heard a noise.
Old 04-19-2015, 12:42 PM
SpokaneSpeed's Avatar
Since u took the head off, you basically made it impossible to test for bent valve unless u have the proper equipment, which I doubt you do. Your only option at this point is to take it to a machine shop and have them vacuum test it...
b16b18
12
11-01-2007 02:04 PM
JDM_SOHC
06-25-2006 01:57 PM
lkailburn
09-21-2004 03:49 PM
JdmIntegra98
07-03-2003 03:58 PM
Quick Reply: How do I check for a bent valve
