HELP: Idle problems/CEL codes for GSR
hey all
my car wasnt driven for 2 weeks. i came back to start it up and battery was dead.. so i jumped it. it drove fine for 15 minutes... i parked it and came back an hour later. it drove ok for about 5 min, and then the CEL came on. the idle is rough around 1400rpm when i am in neutral, and the car is very jerky to drive when i shift. anyone know what this is all about?
how do i access the engine codes on my integra, and does anyone have a list of what the CEL codes are?
thanks!
thanks!
Re: HELP: Idle problems/CEL codes for GSR (ajchen)
I just posted this about 10 minutes ago in a post entitled...
"CHECK ENGINE LIGHT"
There is a little blue plastic pin connector behind your glovebox...pull that out, and with the key on ON, take a paperclip and connect the two pins together. You will see a series of flashes of the CEL. Those flashes correspond to a number.
IE:
1 Long flash, 4 short flashes = Code 14
4 Long flashes, 3 short flashes = Code 43
Go here to see what your code means if you dont have a helms:
http://www.c-speedracing.com/faq/05.php
IE:
max240
02-24-2004 04:39 PM
