GSR valve adjustment
Old 06-26-2007, 05:49 PM
old_school_dohcvtec's Avatar
Default GSR valve adjustment
I will be doing a valve adjustment on my GSR later this week and I plan to follow the c-speed article. The article mentions that a modified wrench can be used to do the job. For all the people that used a modified wrench, did you guys heat up the wrench and then bent it? or did you simply just bend the wrench into shape.....
thanks
Old 06-26-2007, 06:28 PM
Bignel00's Avatar
Default Re: GSR valve adjustment (old_school_dohcvtec)
honeslty it doesnt matter you can do it either way , heat up or bend , it still works the same
Old 06-26-2007, 08:19 PM
been there done that
doood's Avatar
you must be one strong sonofabitch to bend a wrench without heating it up
Old 06-30-2007, 12:07 PM
Bignel00's Avatar
Default Re: GSR valve adjustment (doood)
yessir
Old 06-30-2007, 12:46 PM
Liquidgsr's Avatar
Default Re: GSR valve adjustment (Bignel00)
isn't there a tool on amazon for valve adjustments so you don't need to do this?
Old 06-30-2007, 12:52 PM
Darth ModerVader
Padawan's Avatar
Default Re: GSR valve adjustment (Liquidgsr)
There is a special tool for the job, but the adjustment can be performed using just a regular wrench, a screwdriver, and a feeler gauge.
Old 06-30-2007, 06:57 PM
THE LORD OF CHAOS's Avatar
i bought the jam nut tool from amazon for my valve adjustment. it was cheap and made the job much easier. i would recommend doing that.
gsr96cx
08-25-2008 06:11 AM
Gomdohree
06-02-2008 05:53 PM
Powered by VTEC
16
01-20-2008 03:47 PM
00preludeh22a
02-21-2007 04:43 AM
SamC
01-24-2003 08:52 AM
Quick Reply: GSR valve adjustment
