Fix your starter for $5-$10 no special tools
Old 04-04-2012, 06:20 PM
fcm
Old Fart
fcm's Avatar
Default Fix your starter for $5-$10 no special tools
Second time around...
The most common problem with Honda starters is worn out high current contacts, it is an easy fix, no special tools needed.
Start by removing the starter solenoid back plate, [3x7mm machine screws].
The white insulator around the batt. cable post will just fold off.
With back plate removed you can see/access the solenoid "plunger"
Remove the plunger, carefull there is a spring on the plunger push rod.
You can now see the high current contact, "brackets" held in place with the studs and nuts that also hold the batt. cable, [left] and starter motor power lead from solenoid, [right].
Undo the nuts and remove the parts and lay them out so you will know how they go back together.
Easy to see the bad ones.
Rinstall the studs with the new contacts and all the pieces in the correct order, DO NOT tighten nuts yet, insert the plunger and push it all the way in "hard" and hold it in untill the nuts are tight.
Once the nuts are tight remove the plunger and wirebrush the contact "ring" on the plunger clean, if it is bad you can use a fine Emory cloth on it.
Reinsert the plunger and push lightly untill it bottoms out, then push on it hard, it should move another 3/16-1/4", [collapsing "leveling spring" on the back og the plunger], if good, reinstall back cover and connect starter motor power lead and test the starter.
The parts, [high current contact "brackets"]
can be found at any starter/alt. repair shop, just take your old ones in to match them up, should cost beteen $5 and $10 for the pair.
Old 04-04-2012, 06:22 PM
EK9
Dc4LsTeG's Avatar
Default Re: Fix your starter for $5-$10 no special tools
nice write up
Old 04-04-2012, 06:30 PM
fcm
Old Fart
fcm's Avatar
What the hell???, 45min. of typing and posting pix and all that is left is a pic of the starter????
Dc4LsTeG are you being sarcastic or are you seeing the whole post, 5-6 pics? 94
Old 04-04-2012, 06:31 PM
EK9
Dc4LsTeG's Avatar
No? The post changed. I saw the whole original post I wasn't being sarcastic
Old 04-04-2012, 06:34 PM
B4RK3R's Avatar
Aww no text :/
Old 04-05-2012, 12:03 AM
NemesisCBR's Avatar
Damnit i want to read this!
Old 04-05-2012, 12:35 AM
bnetkillzone's Avatar
Wanna see this write up lolz.
Old 04-05-2012, 12:44 AM
B20ztek's Avatar
damn, thats baddass! So simple put it in a vice and BAM problem solved lol
Old 04-05-2012, 05:46 AM
heato's Avatar
Damn I would of loved to see this write up.. My starter is going bad too><
Old 04-05-2012, 07:20 AM
fcm
Old Fart
fcm's Avatar
I will redo it tonight.
When I go to edit, there is nothing at all there, not even the single pic that does come up, mods, you can remove what is left of this post, I can't even deleat it. 94
Old 04-05-2012, 08:50 AM
EK9
Dc4LsTeG's Avatar
To get rid of the pic you have to go to manage attachments like when you add the pics
Old 04-05-2012, 09:02 AM
Spawne32's Avatar
so in short, buy a new one?
Old 04-05-2012, 09:05 AM
EK9
Dc4LsTeG's Avatar
No it was a write up on how to replace the high powered contacts which he said was the thing that usually goes wrong with them when it happens
Old 04-05-2012, 09:16 AM
wanabebuff's Avatar
Boooooooooo....... :thumbsdown: for stupid glitches.
Old 04-05-2012, 09:45 AM
DirtyDA9's Avatar
DAMNN. 45 minutes of typing for only 1 picture to show up? hahah that blows.
Old 04-05-2012, 10:29 AM
fcm
Old Fart
fcm's Avatar
Got it, TY
Still can't deleat the post, but I will try and redo this one tonight.
Old 04-06-2012, 04:11 PM
fcm
Old Fart
fcm's Avatar
Fixed. 94
Old 04-06-2012, 04:37 PM
Technical Hero
HondaPartsHero's Avatar
Here some Toyota part numbers that'll work
http://www.team-integra.net/forum/19...than-20-a.html
And a removal and replacement video as well
http://www.youtube.com/watch?v=cWm8j1SkUD8
Old 04-06-2012, 04:40 PM
el crapitan's Avatar
you see, a long time ago, in a land far far away, people didn't just replace parts; they actually fixed them.
i know. crazy, right?
great write up. thank you for taking the time to share
Old 04-06-2012, 04:49 PM
Spawne32's Avatar
you missed the post last night, there was nothing in the post lol
Old 04-06-2012, 04:59 PM
Nice one! I like it!
Old 04-06-2012, 05:27 PM
wanabebuff's Avatar
Nice job man, thanks for doing it twice, too! Definitely a fan of fixing instead of replacing when I can.
Old 04-06-2012, 06:12 PM
gotcha. my bad
Old 04-07-2012, 01:29 PM
fcm
Old Fart
fcm's Avatar
gotcha. my bad
Yea there was some kind of "glitch" and when I posted all that came up was one pic., had to redo it.
The sad part is it took less then an hour to fix the starter, including taking a bunch of shots, and it has taken almost two days to install it because of a seized lower mounting bolt, ended up having to cut the head off the bolt, now it is a stud. 94
Old 06-27-2012, 12:06 PM
Oh look, I can change this
deschlong's Avatar
Wow. Wish I had this back in 2008 when my starter died on me and cost a bazillion dollars to fix when it clearly shouldn't have. In retrospect, though, it was the catalyst to get me to learn more about my car. I've come a long way since then.
Quick Reply: Fix your starter for $5-$10 no special tools
