throttle body?
Old 09-03-2007, 05:22 PM
racereaper7's Avatar
Default throttle body?
i have a jdm b16a second gen and i was thinking about adding a type r intake manifold and throttle body from skunk 2. it this a hard mod or does it just bolt on with little change(what ive heard but want to make sure) and aslo would 68mm or 70mm be better. bigger is probably better but just want to make sure before adding it on. thanks for your help in advance.
Old 09-03-2007, 06:28 PM
LoseRPunKx182's Avatar
Default Re: throttle body? (racereaper7)
from what i've heard port matching it to the manifold is the correct way to size up a tb.
Old 09-03-2007, 09:24 PM
been there done that
doood's Avatar
Default Re: throttle body? (LoseRPunKx182)
bigger is not better. air velocity is more important than air quantity.
leave your stock manifold and tb on there. using itr pieces will only kill what little midrange b16's have and shift the powerband only higher where you wont be able to rev to without additional work.
Old 09-04-2007, 09:57 AM
95 integra's Avatar
Default Re: throttle body? (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">bigger is not better. air velocity is more important than air quantity.
leave your stock manifold and tb on there. using itr pieces will only kill what little midrange b16's have and shift the powerband only higher where you wont be able to rev to without additional work.</TD></TR></TABLE>
Even with bolt-ons and raised compression/stage I cams, 62mm is really probably the best size TB you could roll with. On a stock B16, you might want to jump up to the 60mm TB found on the later model B16s and Integra engines, but I'd steer away from the 65+ range.
B18c1-Integra
13
02-22-2008 05:34 PM
B164DRDL
01-27-2008 08:55 PM
Junkyard2000
09-05-2005 10:49 PM
JforJonathan
10
04-10-2004 12:15 PM
trbob16a
06-21-2002 02:37 PM
Quick Reply: throttle body?
