DIY - 1994-2001 Acura Integra - Oil Pan Gasket **PICS**
With 180k miles, my 15 year old car is in dire need of a new oil pan gasket as It's leaking oil everywhere.
Tools Needed:
- 10mm Socket & Wrench
- 12mm socket & wrench
- 14mm socket & wrench
- 17mm socket
- Extension
- Oil Filter removal tool
- Silicone gasket
remove oil cap
Using a 17mm socket, remove the drain plug & watch out for oil coming out straight into your face. Drinking it is optional.
Or do what I did and drain it into a container to recycle.
Now remove the down pipe that's right below the oil pan & blocking it.
It should be 14mm & 12mm bolts. Oh yea, don't forget to unplug the oxygen sensor
Now remove the dust shield. It should be 17mm bolt & 10mm bolts (3)
Now remove a crapload of these 10mm nut & bolts around the oil pan.
Here it is removed. The old oil pan gasket was ridiculously hard. No wonder it's leaking oil everywhere.
Now put the oil pan gasket onto the oil pan (be careful as it only go in one way.) I also put some RTV silicone around the pan just for precaution. I suggest you use a razor blade and clean up any leftover gasket residue on the oil pan & block before putting the new one on.
Put the oil pan back in and then the dust shield. Tighten up all the bolts and then go back and make sure they're all tighten again.
Since my car have 180k miles on it, no need for any brand name or synthetic. Just put new oil in and enjoy.
**I recommend you change the oil filter also before lowering the car down.**
Tools Needed:
- 17mm socket
- Extension
- Silicone gasket
remove oil cap
