converting my 98 ls from 4 lug to 5 lug
Old 05-20-2014, 05:15 AM
HondaMan234285's Avatar
Default converting my 98 ls from 4 lug to 5 lug
Does anyone know a good site that shows all the components I would need to swap my 98 ls from 4 lug to 5 lug?
Old 05-20-2014, 05:31 AM
kaycee_00's Avatar
Default Re: converting my 98 ls from 4 lug to 5 lug
Its straight bolt on if your getting usdm/jdm itr hubs and trailing arms. Jdm ones use 36mm axles though.
Old 05-20-2014, 06:37 PM
Is there another way to swap over than buying the jdm swaps? Never done that before so I am not sure what all is necessary to change
Old 05-20-2014, 06:48 PM
B_Swapped93's Avatar
USDM 5 lug...don't bother with changing the hub etc that's way to much of a pain.
Old 05-20-2014, 06:58 PM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Buy a full 5 lug swap from a 96-00 EK9 CTR. This has the "32mm" splines so you can use any USDM civic/integra axles. You WILL NEED an alignment if you use this on a 5G civic or Integra.
If you buy a JDM ITR 5 lug, it will be cheaper, but you'll need to be creative with the axles. 5G prelude axles work almost 100%. You'll need to swap the inner passenger side CV cup from a B series axle.
If you buy a USDM ITR 5 lug...you're a bad person. It's probably stolen.
A complete 5 lug swap comes with complete rear trailing arms and front spindles with hubs, brakes, everything. Very complete ones will usually come with control arms and shocks and springs too.
You also need 5X114.3 wheels. Duh. They need to be 15" or bigger to fit the brakes.
Jdmenginescorp.com has sold me a couple nice ones....for cheap because b serious is #1. But retail is still cheap. Like $780ish shipped without wheels. About $1500 with wheels.
Old 05-20-2014, 07:02 PM
B serious's Avatar
If you want to piece together a conversion with new, US dealership parts, you'll need these from a ITR:
-hubs
-wheel bearings
-rotors
-calipers
-caliper brackets.
-brake pads
-5 lug wheels.
-a million dollars to pay for it all.
Old 05-20-2014, 07:10 PM
brah we got them hella tyte 5-lug swaps going for $550 here..
only reason I'd swap to 5 lug is so I could rock CCW's
Old 05-20-2014, 07:57 PM
Garage_Spec's Avatar
Classic hard parking quote! Lol
Old 05-21-2014, 08:23 AM
B serious's Avatar
Well...the reason for a 5 lug is typically just looks.
4 lug has some advantages:
-wheel selection. HUGE advantage if you want 15 or 16" wheels.
-mini cooper rotors and ITR calipers for the front. EP3 rotors in back with itr calipers. This combo is easier to install and much cheaper than a full 5 lug swap.
The nice thing about the 5 lug besides the look is that the 5th lug helps spread the load on the wheel face (insert load and face joke here). That means slightly less chance of breaking a wheel and a little more hub and bearing life.
CHolland23
03-03-2008 12:25 PM
jc2801
06-07-2007 10:05 AM
Vl4d
05-22-2007 11:19 AM
RhdRicheeee
11-21-2005 04:06 PM
00hatch98r
03-31-2003 03:58 PM
Quick Reply: converting my 98 ls from 4 lug to 5 lug
