Clutch Slave Cyl. - What lube to use?
1 Post
Ok, I've searched on the squeaking sound coming from my clutch slave. Now my question is, what type of grease should I be using to lube the end of the slave that contacts the fork and the shaft itself?
I hear Wheel Bearing Grease, Caliper Grease, and High temp urea grease...Which is correct?
Re: Clutch Slave Cyl. - What lube to use? (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg »</TD></TR><TR><TD CLASS="quote">What's urea grease, isn't urea a chemical in ****?</TD></TR></TABLE>
give it a shot, won't cost you anything
Stoich
11
11-06-2007 04:30 PM
chomorro
12-21-2006 09:56 AM
