Clutch pedal goes to floor
Old 11-19-2009, 06:46 PM
fcjohnny's Avatar
Default Clutch pedal goes to floor
I was driving to bring my friend home and my Clutch pedal loses a lot of pressure. I have to press the clutch all the way to the floor for I to engage. What the hell cause this? Drive a 94 rs
Old 11-19-2009, 07:00 PM
gabe768's Avatar
Default Re: Clutch pedal goes to floor
check to see if your topped off with brake fluid, that happened to me and that was the problem
Old 11-19-2009, 07:11 PM
seanbev24's Avatar
I'd start by inspecting for leaks and bleeding the system with new fluid since it'll only put you out a few bucks.
If that doesn't work, it could be a bad master cylinder, slave cylinder, maybe pressure plate?
Old 11-19-2009, 07:33 PM
ILS_09's Avatar
Check for any leaks from your slave cylinder and clutch master cylinder. Typically, the clutch/brake fluid for the clutch reservoir wouldn't go down unless there is a leak somewhere. Make sure your clutch reservoir (or whatever it's called) is full.
EddieLe76
01-14-2010 01:50 PM
Gomdohree
04-24-2008 06:20 AM
Lb1atx
09-07-2007 05:16 AM
eg6sittingon57cs
08-08-2007 10:44 AM
The Droogan Leader
10-06-2006 12:05 PM
Quick Reply: Clutch pedal goes to floor
