Car drives in neutral! Help!
Ok so the other day I turned my car on and while it was warming up the car bogged like if it wanted to move and all the sudden it turns off. When I turn it back on, I released the clutch pedal and it cut off again. I tried putting it in gear and drive and it doesn't move and if I let go of the clutch it turns off..goes in all gears but 5th and none of them is possible of driving.. I could drive in neutral but can't pass like 4k rpm... Help please
92 da9 manual
92 da9 manual
Re: Car drives in neutral! Help!
happend to me not long ago. is your clutch super stiff?
what it was for me was a faulty throw out bearing. it was geting stuck ON.
replaced with the replacement i had but forgot to install lol and was good as gold
hope that help's
hope that help's
92 da9 manual
92 da9 manual
Have you recently replaced your clutch?
Cool Cool Island Breezes. BOY-EE
Why are people saying its a clutch or hydraulic system failure? He pushes the clutch in and the car is fine. He lets the clutch out IN NEUTRAL and the car dies. That sounds like a trans or shift linkage/fork failure. The trans should be in neutral, but it's in some gear instead.
OP, have you checked these out yet?
So I have a 1997 Acura Integra and it has a stage two clutch in it so I can start my car with clutch pushed in I can shift through gears but car will just bog down and then when I try ingageing in neutral car will move but in any of the other gears car just bogs down what could this be
92 da9 manual
92 da9 manual
