Brakes cause engine to rev, vacuum leak?
Old 01-09-2005, 11:24 AM
HOOKSH's Avatar
Default Brakes cause engine to rev, vacuum leak?
pedal feels a little softer when pressed, but at a normal idle of 750-800, if i press the brakes rapidly 5 or so times, the idle will go up to near 2k RPM. im guessing its a vacuum leak, but not sure where, any ideas anyone? i know the brake booster is good because it worked with my B18C1. motor is currently a B18B1 from a 96 LS, car is a 97 GSR. any weird things with an LS motor in a GSR that would cause brakes to raise revs? if not, what would be leaking, other than brake booster?
thanks for any help ya'll can provide.
-Matt
Old 01-09-2005, 11:28 AM
B2FiNiTY's Avatar
Default Re: Brakes cause engine to rev, vacuum leak? (HOOKSH)
That is normal. Your booster is working
Old 01-09-2005, 11:30 AM
95 integra's Avatar
ecu increases rpms to compensate for the extra load on the engine.....does it on mine too, just not to 2k. If it idles fine then its probably not a vacuum leak, because if it was a leak it would raise the idle.
Old 01-09-2005, 12:17 PM
Racermech's Avatar
Default Re: Brakes cause engine to rev, vacuum leak? (95 integra)
Same here my 96 LS revs up. Asked a honda mechanic and they said 100% normal
Old 01-09-2005, 12:20 PM
aznballer's Avatar
yeah it happens on my car and my friends mitsu, so i think its normal
hefftone79
09-18-2011 08:51 PM
B16A CRX
05-06-2009 04:17 PM
stripes777
04-27-2008 02:34 PM
supertuner91ef
12-20-2007 05:40 PM
StupidSlowRSX
03-17-2004 04:38 PM
Quick Reply: Brakes cause engine to rev, vacuum leak?
