Blox coilovers?
Blox coilovers?
Any thoughts???
Each BLOX Racing coilover system is designed with specifically matched spring rates and shock valving to offer enthusiasts unparalleled handling characteristics, while maintaining suitable ride comfort and quality.
The Tuner Series is designed to meet the needs and demands of daily driving and high performance weekends at the local road course.
Tuner Series: BXSS-00100
* Front: 10 kg/mm (559 lbs/in)
* Rear: 8 kg/mm (447 lbs/in)
The Competition Series is designed for the rigors of high performance road course driving and racing. Enthusiasts are able to fine tune and maximize their suspension set-up by easily adjusting their vehicle s ride height and corner weights.
Competition Series: BXSS-00101
* Front: 12 kg/mm (671 lbs/in)
* Rear: 10 kg/mm (559 lbs/in)
The Drag Pro Series is strictly designed for drag racing. Drag racers can properly set-up their suspension, which is often overlooked, by adjusting their vehicle s ride height and corner weights to compensate for front end lift and rear end squatting. Greatly improves 60-ft times and high speed stability.
Drag Pro Series: BXSS-00102
* Rear: 18 kg/mm (1,006 lbs/in)
Package Contents
* 4 full-bodied coilovers
* Spanner wrench
* Shim/spacer kit (for 1996-2000 Honda Civic)
Applications:
* 1992-1995 Honda Civic; 1994-2001 Acura Integra
* 1996-2000 Honda Civic
Product Highlights
* Coil springs are CNC-wound using SAE 9254 steel
* Mono-tube shock design (non-adjustable)
* 46mm piston, 20mm shaft
* FINA shock oil, high pressure Nitrogen gas
* Height adjustment range: up to 4
Package Contents
* Spanner wrench
Applications:
Product Highlights
Re: Blox coilovers? (hondatuner020)
wonder what the valving is like. looks like they are non adjustable. someone will have to try them & see how well it matches the rates.
Re: Blox coilovers? (idrivesideways)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idrivesideways »</TD></TR><TR><TD CLASS="quote">wonder what the valving is like. looks like they are non adjustable. someone will have to try them & see how well it matches the rates. </TD></TR></TABLE>
definately adjustable. it shows the tool you use to adjust it in the picture
Found this thread doing a search... Anybody had any good/bad experiences with Blox coilovers? I am looking at the competition ones... just looking for input before spending the money. PM me with feedback!
Re: (idrivesideways)
For slightly more money, I would go with the proven koni and ground control combination. The koni's have adjustable dampening and a warranty. They are a proven combination, and you can also get whatever spring rates you desire (up to a certain level as the koni's are valved up to a certain rate)for your application/driving style and comfort.
Re: Blox coilovers?
I'm actually looking into this same setup as well. New to the suspension game. When I originally purchased my car it came with the cheap ebay coilovers on stock shocks and the ride sucks! So anything besides that will help. Open to any advice u all may have. Looking to spend about $600 or so.
Re: Blox coilovers?
https://honda-tech.com/forums/suspension-brakes-54/click-here-all-you-curious-about-suspension-setups-their-costs-reliability-2967499/
@ $600 go w/Progress CSII
Innes
418
07-01-2015 05:40 AM
johnnyap1db8
Suspension & Brakes
06-17-2012 09:20 AM
PhongN
Suspension & Brakes
03-03-2009 05:30 PM
Innes
09-17-2008 08:10 AM
