Lsv Blue Smoke
Old 07-11-2011, 05:18 PM
mattyp1020's Avatar
Default Lsv Blue Smoke
cant figure what the problem is i got a rebuilt lsv swap its been burning oil pretty consistantly blue smoke out the exhaust when it idles at start bearly no smoke just smokes alot when im driving my friends told me could bge bad valve steam seals but im pretty sure i got new ones during the rebuild what i think it is is that i noticed theres no pcv valve installed nothing even on the black box behind the block could this be why ..?
Old 07-11-2011, 07:43 PM
EJ1_CRIS_909's Avatar
Default Re: Lsv Blue Smoke
Yes that could be why, pcv valve is VERY important. DO NOT DRIVE UR CAR WITHOUT IT!!!!!
Old 07-11-2011, 08:00 PM
racebum's Avatar
not really
if the black box is open the case is venting. if the vacuum side is plugged it won't cause smoke like this. the main cause of this would be
1. rings that haven't seated or won't due to various reasons
2. not replacing valve guides in the head when the valve job was done....or how well the valve job was done
3. valve seals...probably not this since a monkey could do this right.
good chance it's one of the upper two.
Old 07-11-2011, 08:07 PM
Yes really...
It could cause smoke due to the crankcase pressures if it was plugged.
Pcv is used to recirculate the pressures built up in the crankcase.
Too much pressure causes oil to seep past things like the rings and gaskets.
Old 07-11-2011, 08:28 PM
Hidenplanvew's Avatar
I though you said not to drive it if its not hooked up now your saying plugged .... More then anything rings didnt seat right or someone didnt replace valve seals
PCV is an emissions thing.. you dont want it venting into the atmosphere because of the HC. So it gets sucked back into the intake manifold to be burnt off
Old 07-11-2011, 09:09 PM
Because alot of people dont kno the purpose and plug it up after takin it off. I have worked on a few ghetto rigged cars that have done that.
Regardless, its needed to run correctly or some type of breather set up.
Old 07-11-2011, 09:37 PM
racebum's Avatar
Yes really...
you just making up the story as you go?
magic plug maybe?
i'm not sure about you but nothing actually means nothing in my world. like it would mean no pcv and an open hole. that's generally how i would receive the word "nothing"
you're right though. if the op is lying about his own car and making a fake post while the box is actually plugged then yes it can lead to oil burning
Old 07-11-2011, 10:15 PM
Thanks for the flaming, its greatly appreciated ... I bet you feel better now.
Ya now that you pointed it out, i do understand now. What i read was that the black box wasnt even on (prob dyslexia), and when its not on ive seen people not too familiar with cars plug them. And thats why i stated that.
So in my part, ya i misread the information and didnt notice that he DID have the black box on.
Old 07-11-2011, 10:27 PM
racebum's Avatar
it's okay. i hangout in general discussion and debate a lot. we're usually complete flaming ******** to each other
nothing personal lulz
Old 07-11-2011, 10:34 PM
Its all good
Old 07-12-2011, 01:50 AM
*DRAMA*'s Avatar
my lsv was doing the same, i took it to a shop and it had a bent valve and broke piston in first cylinder lol
Old 07-12-2011, 10:24 AM
mattyp1020's Avatar
i know the rings are new had a valve job done not to long ago by a master tech and i have a shitty obd0 manifold the ones with all the stupid vaccum hoses on a obd1 b16 head could that also be a factor and no pcv valve at all installed
Old 07-12-2011, 10:28 AM
mattyp1020's Avatar
and there is a black box behind the block just no hoses going anywhere to a pcv valve or anywhere else just the black box
Old 07-12-2011, 10:41 AM
racebum's Avatar
rings didn't seat or the valve job was off
if the block wasn't bored, honed and fitted with larger pistons there's the 1st place i would look
new rings on old pistons only works if there is no cylinder distortion which means you measure out of round with a bore gauge
do a compression test when the car is warm and see what numbers you come up with
Old 07-12-2011, 11:08 AM
Builda'Teg_92's Avatar
^^ dont you mean a leakdown test for a better reading??
do a leakdown test,
hissing out the dipstick = rings
hissing in intake mani= intake vales not seating good ect. ect.
your gauge should be under 10% which is normal
Old 07-12-2011, 02:35 PM
racebum's Avatar
do a leakdown test,
if he has access to one it would be even better. compression generally will reveal leaking but a leakdown would be best
Old 07-12-2011, 07:40 PM
I would do both personally but I have both Compression tester and leak down.. but I own my own
jvly13
Honda Civic (2006 - 2015)
06-03-2019 04:18 PM
Da Cord
04-10-2018 08:01 AM
civtic
01-13-2008 07:38 AM
elrandeeto
08-14-2005 03:18 PM
Quick Reply: Lsv Blue Smoke
