Antenna question
Antenna question
Hey guys, I just recently installed a new Pioneer deck, everything went fine, except that whenever I turn on the radio my antenna won't go up. I know the wire for the antenna is green with yellow stripe on the harness, but how should I go about raising it up when the radio is on.
I had this problem when I put in my Pioneer head unit. I don't remember offhand which wire on the unit I connected to power the antenna, but it was light blue. I would go look, but there's a monsoon right now and I'm lazy. I've had it hooked up this way for over a year now with no problems. Good luck.
Re: Antenna question (djtony5)
screw the antenna....it looks retarted heeping off the back of an integra trunk. I purposley cut my antenna wire when I got a new deck. I still get excellent radio reception. Best of both worlds
i got the same problem, my antenna wont go up after i installed my cd player. i dont want it to go up anyways because i always listen to cds. but its the principle of the thing
Re: (kimo98GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kimo98GSR »</TD></TR><TR><TD CLASS="quote">Shave the antenna and get XM radio.</TD></TR></TABLE>
Re: Antenna question (taltares)
had the same problem when it was professionally installed. I took it back and they did it in less than 10 min!
I'm getting my XM though soon! The shop has a blow-out sale, the kit is selling for $20 after rebate (The unit + the brain)!!!
Re: (kimo98GSR)
Right On !
Right On !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by taltares »</TD></TR><TR><TD CLASS="quote">hook the blue with white stripe up to the power antenna wire</TD></TR></TABLE>
Re: Antenna question (crazyd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyd »</TD></TR><TR><TD CLASS="quote">had the same problem when it was professionally installed. I took it back and they did it in less than 10 min!
I'm getting my XM though soon! The shop has a blow-out sale, the kit is selling for $20 after rebate (The unit + the brain)!!! </TD></TR></TABLE>
holy crap.. that is pretty cheap... is this a big store or just a small shop in your area?
Re: Antenna question (Pythagoras)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pythagoras »</TD></TR><TR><TD CLASS="quote">screw the antenna....it looks retarted heeping off the back of an integra trunk. I purposley cut my antenna wir</TD></TR></TABLE>i just unplugged the harness today, so now i dont have that stupid *** antenna up. what is the point of having the antenna up when your listening to cd's? and i never listen to the radio.
Re: Antenna question (i luv my 97 ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i luv my 97 ls »</TD></TR><TR><TD CLASS="quote">i just unplugged the harness today, so now i dont have that stupid *** antenna up. what is the point of having the antenna up when your listening to cd's? and i never listen to the radio.</TD></TR></TABLE>
weerrrrrrd
weerrrrrrd
I had the same problem with my pioneer head unit. I ended up buying a s2k antenna (not a power antenna) from honda for $27, and an install kit for $15 from a fellow HT'er. Install took 45mins. Looks a lot better in my opinion. good luck either way.
what is the other yellow and blue wire i see at the driver side that is little bigger than the antenna wire? my friend cut that wire first but it didnt work.
yea, i ran into the same problem when installing my pioneer head unit with my 6 channel amp... but after a little figuring out... i hooked up the brown/white from the oem harness to the blue/white or blue from the radio harness, but then again it also depends on the year of your car as well since the 97+ harness is different than years before it..
try this link
http://www.installdr.com/Harnesses/HA-Wiring.pdf
try this link
