all these a/c threads, who can help me replace my belt?
Yea, its that time of the year. Its hot as hell and I neglected to change out my A/C belt because of that bastard mount in the way. Can anyone point me to a How-TO to replace that A/C Belt? I never replaced it when i changed out my crank pulley, so now I am paying for it because of the 100+ temp and leather seats in a all black car.
Thanks in advanced, and yes i did a search for A/C and Air Conditioning.
http://www.team-integra.net/se...=1044
thats the article for changing the timing belt, it shows what u need to do to get the AC belt off as well
Re: all these a/c threads, who can help me replace my belt? (SoEvoL)
Put front of car on jack stands. Loosen splash shield behind front driver side tire enough to get it out of your way and un-do the two bolts that hold the upper drivers side engine mount to the body. Loosen the AC belt pulley. Loosen the AC belt tension adjuster locknut and back out the tension adjuster. Remove belt....the rest is pretty obvious.
Re: all these a/c threads, who can help me replace my belt? (miketegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miketegra »</TD></TR><TR><TD CLASS="quote">Put front of car on jack stands. Loosen splash shield behind front driver side tire enough to get it out of your way and un-do the two bolts that hold the upper drivers side engine mount to the body. Loosen the AC belt pulley. Loosen the AC belt tension adjuster locknut and back out the tension adjuster. Remove belt....the rest is pretty obvious.</TD></TR></TABLE>
thanks
thanks
ShinyNewPenny
08-08-2008 06:45 PM
