ABS stopped working. Help!
Old 03-21-2009, 09:12 PM
rhino87's Avatar
Icon2 ABS stopped working. Help!
My ABS has stopped working, I noticed a few weeks ago when it was raining. I'm sure it was working 1 year ago...
Here's what I know.
- ABS doesn't work
- No Check Engine Light
Here's what I've done
- Cleaned front ABS sensor (will clean rear sensors asap)
Please help. Suggestions would be appreciated.
Thx
BTW: It's a stock 99 Integra GS-R.
Old 03-21-2009, 09:15 PM
emooheo's Avatar
Default Re: ABS stopped working. Help!
check the code. I believe you need a paperclip to jump something. Search for it I'm sure you can find it.
Old 03-22-2009, 02:36 AM
vladd's Avatar
Here's what I know.
- ABS doesn't work
Thx
a problem with the abs won't trigger the check engine light, there's a seperate abs light. is that on? if yes, then definitely check the code first.
Old 03-22-2009, 10:19 AM
rhino87's Avatar
The ABS light is off. Even with a paperclip on the blue connector it doesn't turn on or blink. What could it be?
Old 03-24-2009, 08:47 PM
rhino87's Avatar
is there an ABS computer? if so, were is it located?
Old 03-24-2009, 09:48 PM
vladd's Avatar
no idea what it could be then. the computer's behind the right quarter panel plastic. you gotta pull out the back seat to get the plastic off. if you're going to try putting in a new computer make sure you use a 98+ one as the older ones are different.
Old 03-24-2009, 09:57 PM
lsvtecwill's Avatar
Check the ABS fuses.
1baddturbosi
06-06-2008 05:23 AM
94integrasc
06-27-2006 07:12 PM
Spectrum24x
04-02-2006 07:07 PM
DubFat
04-15-2005 10:04 PM
92LudeSI
05-31-2003 12:51 AM
Quick Reply: ABS stopped working. Help!
