ABS light= no vtec???
Old 07-14-2005, 04:50 PM
t_lager's Avatar
Default ABS light= no vtec???
Just wondering if an abs light acts as a cel when vtec will not kick in?
Thanks in advance
Old 07-14-2005, 05:03 PM
Yoinked's Avatar
Default Re: ABS light= no vtec??? (t_lager)
check engine light=no vtec, abs light=no abs (in case you dont know, anti-lock brake system)
Old 07-14-2005, 05:10 PM
t_lager's Avatar
Default Re: ABS light= no vtec??? (EH HatchuBacku)
Sorry if i wasnt clear, I know the abs will not work with the abs light on but should vtec still kick in?
Old 07-14-2005, 05:20 PM
Yoinked's Avatar
it should but i dont have abs so i dont know for sure
Old 07-15-2005, 04:15 AM
t_lager's Avatar
anyone know for sure??
Old 07-15-2005, 05:06 AM
AllMotorDan's Avatar
why would an abs light mean no vtec....this is a dumb question. If you had problems with your vtec you would get a cel and it'd probably be code 21 or 22
http://www.team-integra.net/se...D=493
Read that and it'll tell you why your abs light is on
Old 07-15-2005, 05:20 AM
I am a (Trial User) Army
litterbox's Avatar
Default Re: (SpoonSirG)
This isn't a dumb question, I see the reasoning he has behind asking it.
Old 07-15-2005, 06:52 AM
simon98h22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH HatchuBacku &raquo;</TD></TR><TR><TD CLASS="quote">check engine light=no vtec</TD></TR></TABLE>
Not necessarily.
As far as I know, ABS light should not affect VTEC.
Old 07-15-2005, 07:46 AM
Deluzional's Avatar
Default Re: (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">This isn't a dumb question, I see the reasoning he has behind asking it.</TD></TR></TABLE>
unless the cel actually turns on, then vtec and your entire engine would be hindered, but ABS has nothing to do with his vtec, your brakes will just lock up
Old 07-15-2005, 02:29 PM
t_lager's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonSirG &raquo;</TD></TR><TR><TD CLASS="quote">why would an abs light mean no vtec....this is a dumb question. If you had problems with your vtec you would get a cel and it'd probably be code 21 or 22
Read that and it'll tell you why your abs light is on</TD></TR></TABLE>
I dont have that many post here and this is a good reason why, there is always an ******* that needs to make his useless post (SpoonSirG). I know how to check the codes, Vtec is not kickin in and Im not sure why, the ABS light is on and wasnt sure if that was the cause or not. I just got the car and am trying to get one thing figured out at a time. thanks to everyone else
Old 07-15-2005, 02:35 PM
hideandgoseiki's Avatar
My abs light is on and vtec still works.
Old 07-15-2005, 02:37 PM
t_lager's Avatar
Default Re: ABS light= no vtec??? (hideandgoseiki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hideandgoseiki &raquo;</TD></TR><TR><TD CLASS="quote">My abs light is on and vtec still works.</TD></TR></TABLE>
Thank you very much, thats what i had to know.
Old 07-15-2005, 04:07 PM
karwan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t_lager &raquo;</TD></TR><TR><TD CLASS="quote">Sorry if i wasnt clear, I know the abs will not work with the abs light on but should vtec still kick in?</TD></TR></TABLE> Vtec has nothing to do with your ABS. If light is on , u have no ABS... My ABS don't work either. ABS modeulator vibrates for about 15 secs, then light comes on in my dash.
Old 07-15-2005, 04:11 PM
veggiemaster's Avatar
Default Re: ABS light= no vtec??? (4drGPGS-R)
Yup, the abs computer is completly seperate from the main ECU.
Old 07-15-2005, 07:23 PM
ERIC!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drGPGS-R &raquo;</TD></TR><TR><TD CLASS="quote"> Vtec has nothing to do with your ABS. If light is on , u have no ABS... My ABS don't work either. ABS modeulator vibrates for about 15 secs, then light comes on in my dash.</TD></TR></TABLE>
yea mine does that too. why does it do that? i just got tired of it and unhooked it from the battery.
Old 07-15-2005, 10:58 PM
phateless's Avatar
i heard from a mechanic that the abs unit needs to bled seperately. can anybody confirm?
Old 07-16-2005, 05:27 AM
t_lager's Avatar
Default Re: (phateless)
yes, the abs unit does have to be bled seperately, there is a bleeder valve right on top of the unit, be careful where you let the brake fluid shoot out cuz its not too good for paint.
Old 07-05-2006, 12:20 PM
lockheedload's Avatar
Default Re: ABS light= no vtec??? (negtegra.)
not true at all..i had a cel for idle air temp and my vtec still engaged.
jrmullins85
09-24-2015 05:40 AM
DC206R
10-18-2009 09:26 AM
Accord2k-Hybrid
10-27-2005 09:41 AM
310HPS2k
09-25-2005 06:09 AM
Quick Reply: ABS light= no vtec???
