94 integra LS. Idle revs high to low while stopped.
Old 08-17-2008, 11:11 PM
GREENMOB$TER's Avatar
Default 94 integra LS. Idle revs high to low while stopped.
as the title states, when I'm at idle, stopped at a light or just stopped, the idle goes low to high low to high. puzzles the hell out of me. Is this bad?>
Old 08-18-2008, 12:45 PM
Default Re: 94 integra LS. Idle revs high to low while stopped. (GREENMOB$TER)
bump
Old 08-18-2008, 01:07 PM
EJ6JON's Avatar
seems to me like a clogged up Idle air control valve its on the intake manifold just need to take off clean and put back it gets clogged it has a mesh filter
Old 11-13-2008, 09:06 PM
lsxtreme81's Avatar
i donno but mines doing the same problem but it doesn't go up and down it just stay @ about 1300rpm i've messed around with the idle air valve, i have it where i is all the way down and if any higher i'll gradually raise up higher in rpm so right now it's all the way down and sitting on 1300.. what yal think
Old 11-13-2008, 09:10 PM
I requested a short story for a title.
stocker2shocker91's Avatar
Default Re: (lsxtreme81)
ya mines doin it too..im not to worried about it now but it is extremely annoying..
its on the back of the mani between the firewall and manifold right??
Old 11-14-2008, 02:05 PM
mouab18c1's Avatar
Default Re: (stocker2shocker91)
check for vac leaks, bad tb gasket, leaking intake mani gasket........
norcalB18
12-07-2015 10:24 AM
CaliforniaDad
03-15-2012 04:59 PM
gohonda
06-23-2007 01:44 AM
mugen92acintls
12-28-2004 05:38 PM
Quick Reply: 94 integra LS. Idle revs high to low while stopped.
