Question about new installed clutch master
Old 01-08-2007, 08:23 PM
b20acura's Avatar
Default Question about new installed clutch master
i installed my new CMC today using this DIY as a guide
http://www.team-integra.net/se...=1162
at the end of his diy he says there should be about 1/2" of initial play before the clutch gives pressure. i adjusted my CMC till there was no play at all. is it okay for there to be no play? or does it need a little play in it?
Old 01-08-2007, 11:25 PM
keys's Avatar
Default Re: Question about new installed clutch master (b20acura)
It should be fine as long as the pedal isn't constantly putting pressure on the clutch master cylinder. If it is putting pressure on it, then you will wear out your clutch faster. Similar to the advice of not resting your foot on the clutch when it is not being used.
HTH
Old 01-09-2007, 08:43 AM
b20acura's Avatar
Default Re: Question about new installed clutch master (keys)
how do i know if the cmc is constantly putting pressure onto the clutch?
Old 01-09-2007, 10:24 AM
keys's Avatar
You will know if you are constantly putting pressure on it if you have to push the pushrod in to get it attached to the pedal.
civic=goodgasmileage
Honda Civic (2001 - 2005)
06-03-2009 02:33 PM
yangt
Transmission & Drivetrain
10-22-2008 10:54 AM
94accord718
09-10-2007 01:22 PM
fridayfred3p
04-27-2006 03:11 PM
HiAssHell
11-05-2005 05:04 PM
Quick Reply: Question about new installed clutch master
