91 problem
91 problem
My ignition switch went bad this morning, so I called the junk yard to see what they had in stock. I have a 91 5 spd, and all they had was a 91 automatic, but works none the less, just has an extra harness for the neutral/safety switch.
So I replace the switch, starts without a problem, but NOW, I have no radio, and no cigarette lighter socket.....
All fuses have been checked, none are blown.
Any ideas?!
Any ideas?!
Re: 91 problem
Better check again. You've probably got a blown 10A fuse in the under-dash fuse box. Check in the upper-most of the four rows of fuses.
Old Fart
Re: 91 problem
Ditto the above^^^, and do not just eyeball the fuse, test it or replace it with new or known working one.
Question, does the blower motor work, if not, check the main acc. fuse, upper right of fuse box under plastic clip/cover
It is the big green one, [the clip/cover is missing of this one].
Here is a diagram.
Good luck and merry hoho.94
Here is a diagram.
