2001 integra glove box problem
Old 12-24-2010, 07:25 PM
ROMOJDM's Avatar
Default 2001 integra glove box problem
This morning I found out someone tried to break into my glove box after breaking into my car they broke the lock & handle and couldnt open it so the good thing is they didnt steal anything
now my question how can I remove my glove box? to fix it
its locked but since it broken I cant do anything.
can i remove it?
if so how
thanks here are some pictures
its a 2001 acura integraa gs
Old 12-24-2010, 07:26 PM
ROMOJDM's Avatar
Default Re: 2001 integra glove box problem
Any help is welcome
Old 12-24-2010, 07:49 PM
SleeperGSR's Avatar
yea if you look under the dash there should be two screws that you can take out for the hinges on the bottom. once you get them out the glove box should fall out. kind of a PIA to get at, but once you look under there you should see. GL
Old 12-24-2010, 08:11 PM
Myroslav69's Avatar
the above, but you still need to open the top latch first, because even if you unscrew the bottom screws, it will not come out because it is still latched at the top. I say try to break it off without damaging the latch, or finish breaking the lock and unlock the glove box.
THEIVES SHOULD BE SHOT!!!
Old 12-24-2010, 09:02 PM
ROMOJDM's Avatar
thanks for the information guys
Old 12-25-2010, 09:52 PM
94VTEC2TONE's Avatar
try to unbolt the bottom and see if its possible to take the back skin off the glovebox and unscrew the handle i believe that mite work but im not sure. aint touched my glove box in a few weeks when i tore it apart
Old 12-25-2010, 10:23 PM
jdm-style-dc2's Avatar
These are the two screws that hold the lock from the inside of the glove box.
Once you unscrew them the lock will just come off
Now the prolem is how are you going to get into the glove box..
If you removed your passanger airbag in the past and have a JDM air bag tray your can remove the tray and you will see the two screws from there.
Your glove blox is already scratch up and the with a broken lock i would just brake it apart to to take it off , Anyways gloves go for about 15 dollars when people part out their cars.
Old 06-28-2012, 08:23 PM
ROMOJDM's Avatar
thank you everyone
jondaurio
02-09-2014 07:06 PM
tbooks
08-23-2010 07:09 PM
Nat X Stl
07-26-2007 05:59 PM
Eibach95Civic
05-02-2007 05:00 PM
Fatty_1775
05-10-2004 10:02 PM
Quick Reply: 2001 integra glove box problem
