1991 integra DA weather issues?
My mom is having car problems and I was seeing if anybody would be able to help out.
My mom has a 1991 Integra DA when it is running down the highway it dies. When it is hot outside it won't start. It eventually starts but it may take several hours before it starts. She can spray starting fluid into the breather and it will start but it doesn't always keep running. She has changed out the spark plugs, rotor, distributer cap, coil, ICM, tested the fuel pump and it's okay, relay mod is fine, and changed out the fuel filter.
Thanks
Thanks
Re: 1991 integra DA weather issues? (Auby)
your mom does all this???
just check the cables inside distributor connecting to the igniter they might be corroded so best bet is to buy a new distributor.. and check plugs also...
Thanks. I will let her know all that has been said here so she can give it a whirl. If these dont work I will be back with more questions. Again Thanks.
Re: 1991 integra DA weather issues? (mr.beeks)
After taking out the fuel pump and testing it she found that she is not getting power to the fuel pump.
Replace the Fuel Pump Relay... Tons of old Ef's/DA's have that problem. Mine did. Put the new relay in and its been fine.
Waldron Racing
11-26-2013 06:45 AM
Coltmorris
09-11-2009 12:51 PM
civic89si666
03-20-2006 04:54 PM
