***How-To*** Install Valve Springs & Valve Stem Seals
#52
Re: (wildoutwhitegsr)
sorry to bring this back, but i just did my valve seals 2 days ago and when i put compressed air into the cylinder and removed the valve seals, i saw air bubbles escaping from some of the valve guides on the intake side. does this mean those intake valves are bad?? also when i put compressed air into cylinder 2 and i blocked the top of cylinder 3 i could feel air building up on that cylinder and when i let go i felt the air come out? what could this mean??
#55
Re: ***How-To*** Install Valve Springs & Valve Stem Seals (Vtecfool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecfool »</TD></TR><TR><TD CLASS="quote">this has got to be the best how to ever... very detailed instructions! hopefully the pics will still be up when it comes time for me to do this.</TD></TR></TABLE>
in IE, click file save as and it will save the whole page with pictures to your hard drive.
#58
Re: (CompanyFlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompanyFlow »</TD></TR><TR><TD CLASS="quote">You did all of that work with such a nice jacket on? You crazy crazy man </TD></TR></TABLE>
Haha it was the middle of winter I needed something to stay warm in
#60
Re: (solid gsr)
hmmm...
question.
i just re-built my head with itr cams/springs/retainers but u have a few q`s
my stem seals were ALL the same colour ?!?!?! how do i know which stem should have gone to which valve? (it was a b16a2 head)
also on my itr dual valve springs is the top the section that is coloured ? or is that the bottom? will it make a diffrance if they are installed upside down?
help
question.
help
#65
Re: (D-meet07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-meet07 »</TD></TR><TR><TD CLASS="quote">What is the name of the other valve stem removal tool that actually bolts up to the head and has a lever type deal to compress the springs??
It's a Snap-On valve spring compressor tool.
sweet write-up, although I hope I don't have to do this to my car, at least not while it's still my daily driver.
#66
Re: ***How-To*** Install Valve Springs & Valve Stem Seals (import810)
you sir are the man!!!!!!!!!!!! thanks for taking the time to show us this cause this is what im using when i build my h22
#72
Re: ***How-To*** Install Valve Springs & Valve Stem Seals (xionl1350)
Good, except you dont mention how WE ARE SUPPOSEDTO GET TDC FOR EACH CYLINDER with the camshafts off. So, we are supposed to reinstall the cams, holders, timing belt, then rotate it, then do that 3 times ? that doesnt seem practical
EDIT: I just realized the valves will all be closed without cams installed.
Modified by drumminforev at 12:15 PM 10/13/2006
#73
Re: ***How-To*** Install Valve Springs & Valve Stem Seals (wildoutwhitegsr)
I put this in a PDF file for you guys..
Right-click - Save As
http://www.typer.us/Replace%20...s.pdf
