what does offset mean
It's explained in the FAQ:https://honda-tech.com/zerothread?id=1188922
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xoutlawz00x »</TD></TR><TR><TD CLASS="quote">i still don't get it</TD></TR></TABLE>
Did you try using the link in my previous post (by clicking on the word "here"), and read the entire web page on the Tire Rack website?
...from the link above
"The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset."
If the image above doesn't make offest clear, there's not much hope.
Zero Offset
Positive
Negative
nexgen91
Apr 23, 2006 02:46 PM
Todd00
Jun 14, 2004 10:10 AM
