typical offset question
Old Aug 28, 2011 | 10:26 PM
Bstegner's Avatar
Default typical offset question
95 civic 4 door. i want it to sit low but not to low to loose any performance. what is a good offset to fit without any fender work. i was looking at a set of 15x8 +0 rota grid-v. any help or pics is appreciated. thanks
Old Aug 29, 2011 | 05:23 AM
toyomatt84's Avatar
Sanji
Default Re: typical offset question
Without fender work, you're looking at about 15x7 +38 for the lowest you can run with properly sized tires. 15x8's in general, are out of the question.
Old Aug 29, 2011 | 09:16 AM
cubminican7's Avatar
Before I bought my sprinthart cpf's from my boy he was running them on his eg hatch. With a 25mm 4x100 to 4x114.3 adapter the +45 sprintharts sat flush on his hatch with perfect camber. The wheels were 15x6.5 with 195-55 tires , hope it helps
Old Aug 29, 2011 | 04:15 PM
Bstegner's Avatar
thanks appreciate the help. now i just have to figure out what wheels i wanna run with
what about 15x7 35 offset?
how much fender work would it require for 15x8 25 offset. would it need rear fender work too or just front, and how much.
Old Aug 30, 2011 | 05:17 AM
toyomatt84's Avatar
Sanji
15x7 +35 can work with a little bit of negative camber.
15x8 +25's will need both the fenders and the quarter panels rolled significantly, as well as a bit of negative camber.
Old Aug 30, 2011 | 10:49 AM
doc@tirerack's Avatar
We recommend either 195/50R15 (for the 7" wide wheel) or 225/45R15 (for 7" or 8" wide) for reference.
oskarsEG6
Nov 16, 2011 03:21 AM
2000HondaEm1
Sep 14, 2009 09:10 PM
InfraRed
Nov 16, 2006 07:56 PM
xfrankx
May 25, 2006 10:39 PM
