tire size help
Old May 5, 2009 | 06:25 PM
88'CRXsi's Avatar
Default tire size help
so i just got me some Buddy Club P1 racing SF rims, they are 15''x6.5'' and are going to be put on my CRX which has a 2.5'' drop and a front/rear camber kits, so anyways the question is, Whats a good tire width thats not going to scrub or anything? i was told a 205/50 would be perfect but i just wanted to double check and see if anyone had any opinions. thanks
Old May 6, 2009 | 03:57 AM
Cooper The Tire Rack's Avatar
Default Re: tire size help
The rim width range on the 205/50-15 is 5.5" to 7.5", so you're safe as far as fitment on the wheel.
As for fitment on the 1988 CRXsi, the size we recommend is the 195/50-15 and that would fit without any issues on a vehicle that is bone stock. With a 2.5" drop and a camber kit, I'm not sure the 205/50-15 would fit.
Tires
Old May 6, 2009 | 11:29 AM
nsxtasy's Avatar
H-T Order of Merit
Yup. Stick with 195/50-15.
As a general rule, tires generally don't rub if they are approximately equal to the outer diameter of the stock tire size (preferably within 1 percent) and if they are no more than 20 mm wider than the stock tire size. You have that with 195/50-15, and you don't have that with 205/50-15. On a lowered car, your chances of rubbing are even greater.
Old May 6, 2009 | 11:36 AM
Incidentally, that is the only 15" size we guarantee fitment on that vehicle.
Tires
Old May 6, 2009 | 02:28 PM
88'CRXsi's Avatar
sweet thanks for the help i'll be getting the 195/50's then sence it'll have no issues with it
Old May 6, 2009 | 04:33 PM
UncleD's Avatar
Why not a 215/45?? Same height as a 195/50, and with a 6.5 +42, the 215/45 will fit without rubbing.
Old May 6, 2009 | 05:39 PM
nsxtasy's Avatar
H-T Order of Merit
Originally Posted by clean rice
Why not a 215/45??
Maybe because it's an extremely rare size, with almost no tires available in it. Total number of tires that size sold by the Tire Rack: ZERO. So there's no need to guarantee fitment for a tire size that they don't sell. Ya think?
In fact, the only tire I know of in 215/45-15 is the Toyo T1R. Aside from the fact that it's not that great a tire and won't give you anywhere near as much traction as extreme performance tires like the RE-11 or R1R in 195/50-15, it's also ridiculously expensive in that size. So there's absolutely no reason to buy it, unless you just like wasting your money.
Old May 6, 2009 | 05:53 PM
UncleD's Avatar
Or unless he would like to run something other than a 195. I enjoy my T1-R's, they are a good tire and deliever good dry AND wet weather performance. Why would you compare them to a R1-R anyway??
Old May 6, 2009 | 06:00 PM
nsxtasy's Avatar
H-T Order of Merit
I wouldn't. I would compare them to the Yokohama S.drive, which is little more than half the price in 195/50-15 ($65 at the Tire Rack), with better performance. I've seen prices of $120 and more for the T1R in 215/45-15. Why would you waste your money on the T1R, anyway? That's a lot more money to spend just to get some bling bling.
Old May 7, 2009 | 02:17 PM
88'CRXsi's Avatar
well i just ordered my tires lastnight and i went with the 195/50/15 BF Goodrich G-Force Sport after doing a bunch of research so i'm hoping those will be just fine for daily driving and some racing
CubbyChowder
May 26, 2011 04:47 AM
grandam
Dec 30, 2007 07:57 PM
accordinglyevil
Nov 19, 2007 06:34 PM
MurdersV8s
Jun 1, 2007 06:23 PM
VTECTIME
13
Oct 1, 2002 01:38 PM
