Time to replace my Toyos, looking for options
Old Mar 24, 2013 | 04:59 AM
flippy_ek's Avatar
Default Time to replace my Toyos, looking for options
Hey guys, like the title says, my Toyo Proxes4 are almost fully worn after two summers (6 month runs each) of daily driving. (often very spirited.) Before those, I owned a set of Proxes T1Rs. I was really happy with with both sets but don't really have anything else to compare them to.
I'm kind of budgeting my next set to be around the same price as the Proxes4, which I was able to get for $115 per tire. Is there any other candidates, specifically better tires that I can get for that price range?
I'm certainly not married to the Toyo brand, but was considering them again as I enjoyed them a lot.
Old Mar 26, 2013 | 08:21 AM
flippy_ek's Avatar
Default Re: Time to replace my Toyos, looking for options
c'mon guys! nothing?
I've heard a few people mention they've had good luck with yoko S.drives...
Old Mar 26, 2013 | 10:37 AM
TunerN00b's Avatar
The Proxes 4 were some of the worst tires I've ever ran (that claimed to have performance). Poor dry traction, terrible temperature tolerance, lackluster wet traction, and high road noise. Their only redeeming quality was a soft, comfortable sidewalls, that was probably the primary contributor to poor response.
But, why run an all season tire for the summer? If you want performance, run a proper summer tire.
Old Mar 26, 2013 | 03:42 PM
Lamsta's Avatar
T1R is pretty much top of the line from toyo for street tires but are on the expensive side. you can't go wrong with the S.drives. other choices like falken and even some of the hankook are very good bang for the buck. if i were you, i won't go back to the proxes 4, there are better options out there.
Old Apr 3, 2013 | 04:41 AM
flippy_ek's Avatar
Sounds like I've been missing out! Now that i think of it, I really did find the half-worn T1Rs with stock suspension almost better than when I upgraded my suspension and switched to the proxes4.
based on quite a few reviews, the BFGoodrich g-Force Sport comp-2 seems to be very promising for its price range and I think I'm going to go with those.
Anyone have experience with the BFs vs s.drives? they're only $10 more per tire than the yokos... worth it?
Old Apr 5, 2013 | 12:49 AM
cdubzki S2K's Avatar
the Bfg's have always worked well on my cars. the drag radials, of course hehe.
Old Apr 10, 2013 | 12:22 PM
doc@tirerack's Avatar
Tire size ?
Old Apr 14, 2013 | 06:49 PM
flippy_ek's Avatar
Originally Posted by doc@tirerack
Tire size ?
195/50/15 on a 15x7 wheel
Old Apr 14, 2013 | 07:00 PM
OneJay's Avatar
If you go with a 205/50/15, prices actually come down a little, depending on the tire. Also, I'm guessing that you have a set of winter tires, or another car, since you live in Canada? For all dry driving, I'd say go with a set of ZIIs or RE-11a's.
Old Apr 26, 2013 | 05:14 AM
flippy_ek's Avatar
I don't drive the car in the winter, the roads here are caked with salt in the winter and I want to preserve the car as much as possible.
I typically drive it from late April to early November. It rains often here on the east coast so I want to be sure the tires will be up to the task to deal with the wet early summers here. Late summers here are usually dry so it would be nice to have a balance.
Old Apr 26, 2013 | 06:03 PM
jdm18honda's Avatar
I have had good luck with nitto neogens but then again I am in fl and my car never sees the white stuff
And they are about 93$ a tire with good handling
Old May 1, 2013 | 06:35 AM
pauld_360's Avatar
haven't tried any toyo myself, but I can only praise Hankook (not sure which model) but I'm getting incredible grip when you get them heated up
Old May 1, 2013 | 05:56 PM
1998GsRIntegra's Avatar
Have you considered the BFG Rival?
Old May 2, 2013 | 10:26 AM
flippy_ek's Avatar
I looked at it and I think it's just a tier above what I should be looking at given my less-aggressive setup:
- KYB AGX adjustable struts with H&R Sport springs
- EG/DC front subframe to accomodate K-swap
- Whiteline EG/DC front 24mm solid sway bar w/energy endlinks
- OEM rear Si/SiR/EL 13mm sway bar, soon to be 19mm UltraRacing
I ended up ordering the BFG sport comp-2's this morning which seemed better for daily duties + spirited weekend drives. I'll write a review on the new setup and the feeling from switching from the Toyos.
Old May 2, 2013 | 04:15 PM
Cool, just wanted to make sure you had at least heard about them since they pretty much just came out. From what I've read so far, it looks like they put the Direzza Z2 to shame.
Old May 2, 2013 | 04:20 PM
Fliptard's Avatar
I have the BFGoodrich g-Force Sport comp, which they don't make anymore, and those tires have some awesome traction. For as much as I spin them :X, they don't wear very fast. I love them
Old May 3, 2013 | 02:00 PM
In your size, the BFG Sport Comp2 or the Dunlop Direzza zII would be great, with the Yokohama S.Drive a half step down.
Crono139
Jun 25, 2008 09:02 AM
06siracer
Honda Civic (2006 - 2015)
11
Feb 6, 2008 08:26 PM
ChefBoyardee
Jan 10, 2008 08:12 AM
balistik
Apr 15, 2005 11:06 PM
TheIntegraGuy
Jun 19, 2002 03:55 AM
