spacers????
i want to get spacers so that my rims will sit more flush to the fenders. how much can you go before you need to get extended studs? i was thinking about getting 3mm spacers front and back but i don't want the stud to be too short afterwards.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SaYjAiBaO »</TD></TR><TR><TD CLASS="quote">i want to get spacers so that my rims will sit more flush to the fenders. how much can you go before you need to get extended studs?</TD></TR></TABLE>
Depending on who's talking, you need a minimum of at least six, 6.5, or seven full turns on the lug nuts. If you don't have six full turns, you need to get extended studs (and then you will also need open-ended lug nuts).
I also had a question about wheel spacers. As long as your studs are long enough, how big a spacer can you use I've seen posts that say not to go over 10mm but I found this site that sells 1" kits.
http://heddev.com/miata/produc...01f2d
Anybody using 15 or 20mm spacers on just extended studs?
By the way I'm also looking to move the rear wheels on my 98 accord out to be more flush with fender. Thanks.
SOHCEK-Turbo
19
Feb 23, 2005 09:15 AM
