Spacer and hubcentric ring?
Old Mar 19, 2005 | 11:59 PM
kb798's Avatar
Default Spacer and hubcentric ring?
If I need to use both, will they be in conflict with each other?
Old Mar 20, 2005 | 11:58 AM
jon volk's Avatar
Default Re: (Mike C)
no, if you do use spacers my sure they are hubcentric to prevent any front and shimmy and all that good stuff.
Old Mar 20, 2005 | 04:01 PM
kb798's Avatar
Default Re: (k20 jon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20 jon &raquo;</TD></TR><TR><TD CLASS="quote">no, if you do use spacers my sure they are hubcentric to prevent any front and shimmy and all that good stuff. </TD></TR></TABLE>
Do you mean hubcentric as opposed to lugcentric?
Old Mar 20, 2005 | 11:01 PM
UncleD's Avatar
Default Re: (kb798)
Spacers - anytime you do not fit the wheel FLUSH with the hub you run the risk of a wheel working it's way loose. Also, when you run spacers you need to make sure you still have <U>proper thread engagement./U] When you run the spacers, they pull the lug nut away from the hub, causing less threads to be used.....not good.
Hub-centric rings - Wow, the underline deal is kinda screwed up here, but anyways the hub centric rings are strictly for ride quality. They are generally to help improve the balance of the tire and wheel at freeway speeds or higher. DO NOT use the spacer and hub centric ring, they WILL NOT work together and your wheel will fall off.
There is no such thing as "lug centric." 99% of all wheels use the lug nuts and bolt pattern to help center the wheel onto the vehicle, wether it's a ball seat lug nut or a cone seat, they serve the same purpose but it is IMPORTANT to use cone seat lug nuts with cone seat wheels, ball seat with ball seat.
Old Mar 21, 2005 | 01:41 AM
kb798's Avatar
Hmm...then what is more important? Spacers or hubcentric rings? The reason I ask is because I'm interested in getting Volks, but I want the hubcentric rings so that they're flush with the hub, rather than relying on the lugs. However, the offset might be a little too low for my car so I don't want to rub.
Old Mar 21, 2005 | 06:18 PM
UncleD's Avatar
Default Re: (kb798)
What car/offset/size wheel and size tire? If your car is lowered, how far?
Old Mar 21, 2005 | 08:09 PM
kb798's Avatar
Default Re: (clean rice)
1994 Honda Prelude
Wheels Gramlight 57pro, 17 x 7, 40 offset, and my car is currently lowered on Neuspeed Sports. I doubt I will rub right now since the width isn't that wide and an offset of 40 will barely make it, but I have plans to lower the car with Eibach Sportlines in the future which worries me.
Old Mar 21, 2005 | 10:09 PM
UncleD's Avatar
Default Re: (kb798)
Do 205-40-17's. My main concern would be it rubbing in the back. Eiback sportlines are fairly stiff and I have owned a set, but I would recommend the H&R over the Eibach's, they give a much better stance...the Eibach's tend to sag in the rear.
Old Mar 21, 2005 | 10:18 PM
kb798's Avatar
I was debating between the Eibach Sportline vs the H&R Race, and I wanted a new set of springs that were definitely stiffer since mine are way too soft. I hate going off-topic, but are the Sportlines and the Race fairly similar in stiffness?
Old Mar 22, 2005 | 06:07 AM
UncleD's Avatar
Default Re: (kb798)
Yeah
crazyguy
Dec 22, 2007 12:32 PM
RTW DC2R
Sep 23, 2007 05:41 PM
bp
Apr 5, 2007 03:07 PM
BLUE EH3
Suspension & Brakes
19
Oct 4, 2005 09:34 AM
SimbaDogg
Feb 28, 2004 11:03 AM
