quick tire choice question
Old Apr 8, 2006 | 06:24 AM
doodooheadfart's Avatar
Default quick tire choice question
i broke my left tie rod and i just found out so now my front tires are almost dead
which tire's would you guys recommend for the front for daily driven use in texas for 205/50-15
i look for long lasting and very grippy street tires that will occasionally be taken to the track
Old Apr 8, 2006 | 08:05 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: quick tire choice question (doodooheadfart)
If this is for your '96 Civic Sedan, I recommend the Kumho Ecsta SPT in 195/55-15, which is the best matching size for your car. $62/tire at the Tire Rack. Another excellent choice is the Yokohama ES100 in the same size for the same price. Both are grippy on dry pavement as well as in rain, and will last a reasonably long time.
However, if you are only replacing two tires, you really need to get the same tire as the other two, or something that performs very similarly. You don't want to have tires with dramatically different performance on one end of your car from the tires on the other end; doing otherwise could induce handling problems.
Old Apr 9, 2006 | 08:24 AM
i have dunlop direzza's on all four corners
they are all 205/50-15
and the rears look new while the fronts are bald
should i just buy some new direzzas?
Old Apr 9, 2006 | 08:42 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (doodooheadfart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doodooheadfart &raquo;</TD></TR><TR><TD CLASS="quote">i have dunlop direzza's on all four corners
should i just buy some new direzzas?</TD></TR></TABLE>
Yes. But rotate them periodically to even out the wear, so that they all wear out at the same time. (I keep the tires with more tread on the front on my FWD cars, for this reason.)
Old Apr 10, 2006 | 01:16 PM
if i get new direzzas the back will only have 3,000 miles more than the fronts
sounds good
BuBBa y0!
Jul 4, 2011 05:26 PM
Torontodude
Feb 11, 2008 10:11 AM
98AcuraGS
Sep 14, 2002 07:06 PM
Audi RS4
10
Aug 27, 2002 08:04 PM
Flux
Apr 24, 2002 09:09 PM
