Offset question
I need to know what offset is safe to run on my 00 Si. I have it dropped 1.75ish on Tein Ra's and I am not 100% sure the best offset to run. I plan on only running 15's or 16's but not 100% if 40 offset, 42 offset or 45 offset is the best choice. Also, running 5x114.3 but not sure if that makes any difference. Thanks in advance for any help guys.
Without knowing the width of the wheel, its really not possible to give you an accurate answer. Offset is a measurement from the center of the wheel, so therefore its width matters most.
I would prefer the 40 offset with a 7" wide wheel. That way, it'll allow you enough clearance at full lock to the inner fenderwell, to allow for larger tires. +35 offset is about as low as you can get before outer fender/quarter panel clearance is an issue.
mrlegoman
Jul 6, 2006 01:29 PM
JDM R
Aug 6, 2004 06:04 PM
