lug pattern usdm itr?
Old Nov 30, 2006 | 07:23 PM
bigfigman's Avatar
Default lug pattern usdm itr?
was wondering if anybody could tell me the lug pattern for a usdm ITR, and if its the same on a 04' S2000? thanks in advance!!!
Old Nov 30, 2006 | 07:33 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: lug pattern usdm itr? (bigfigman)
Yes, 5x114.3 on both cars.
Old Nov 30, 2006 | 08:29 PM
old man neri's Avatar
Default Re: lug pattern usdm itr? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">Yes, 5x114.3 on both cars.
Just to ask the question that should be asked.......hubs and offset the same?
Old Nov 30, 2006 | 08:59 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: lug pattern usdm itr? (old man neri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">Just to ask the question that should be asked.......hubs and offset the same?</TD></TR></TABLE>
I know the offsets are not, although the best offset can depend on the wheel width. The USM ITR has 15x6 wheels with +50 offset. The S2000 wheels are 16x6.5 front and 16x7.5 rear for the earlier years ('00-03) and 17x7 and 17x8.5 for the later years ('04-06). Offset is +55 mm front +65 mm rear for all years.
Maybe someone familiar with the S2000 can fill us in on the center bore numbers. The center bore of the USM ITR is 64 mm; on the NSX, it's different front vs rear, and that may be true of the S2000 as well.
Old Dec 1, 2006 | 11:55 AM
bigfigman's Avatar
thanks guys, hope someone can answer the center bore question. i have a 2000 HX that i am installing a USDM 5-lug on and was wonderin if i could get away with 04'-05 S2000 wheels. thanks again!
Old Dec 1, 2006 | 01:50 PM
nsxtasy's Avatar
H-T Order of Merit
You might try asking in the S2000 forum. Someone there should know...
Old Dec 1, 2006 | 02:14 PM
r.wright's Avatar
Center bore (all years NSX, s2000) 70(.1) mm front, 64(.1) mm rear
Old Dec 1, 2006 | 02:39 PM
bigfigman's Avatar
Default Re: lug pattern usdm itr? (mrrlx)
i would end up using four front tires off an 04'-05' S2000, cuz i do believe the rears would be too wide.
Old Dec 1, 2006 | 05:15 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigfigman &raquo;</TD></TR><TR><TD CLASS="quote">i would end up using four front tires off an 04'-05' S2000, cuz i do believe the rears would be too wide.</TD></TR></TABLE>
Remember that the front wheels and rear wheels are different widths (as noted above). So tires that fit the front wheels probably won't fit on the rear wheels. And when you buy a set of used wheels, it almost always consists of two front wheels, and two rear wheels... (and in addition to not fitting the front tires, two of the wheels might not have the proper center bore, either).
Old Dec 1, 2006 | 06:14 PM
bigfigman's Avatar
i meant to say four front wheels. do you mean the center bore mite not fit the itr setup correctly?
Old Dec 1, 2006 | 06:34 PM
r.wright's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigfigman &raquo;</TD></TR><TR><TD CLASS="quote">i meant to say four front wheels. do you mean the center bore mite not fit the itr setup correctly?</TD></TR></TABLE>the fronts from an s2k are 70.1 which would be fine but u may wanna look into hubcentric rings.
Old Dec 1, 2006 | 07:15 PM
bigfigman's Avatar
those are the rings that center the wheel on the hub, correct?
Old Dec 1, 2006 | 07:46 PM
nsxtasy's Avatar
H-T Order of Merit
Correct.
You think you can find a set of four front wheels? Good luck...
Old Dec 1, 2006 | 08:15 PM
bigfigman's Avatar
who knows. i have two pending at the moment. guess we'll see.
Conclusion
Dec 25, 2007 05:11 PM
Mrcrx28
Jul 28, 2006 01:50 PM
b18blackek
Apr 29, 2005 06:34 AM
vtecsoldseperately
Dec 15, 2003 03:20 PM
mister_r0b
Dec 6, 2003 10:34 PM
