how do u polish wheels?
Old Jun 2, 2005 | 12:00 PM
shervin's Avatar
Default how do u polish wheels?
i wanted to polish my slipstreams, is there a diy on how to do it? if not can some one please tell me how to. thanks
Old Jun 8, 2005 | 04:48 PM
ant123's Avatar
Default Re: how do u polish wheels? (shervin)
i hope someone replys....i wna do the same with mines
Old Jun 8, 2005 | 07:10 PM
Martingtrco
Guest
Posts: n/a
Default Re: how do u polish wheels? (ant123)
bump
Old Jun 8, 2005 | 08:06 PM
EK k kay's Avatar
Default Re: how do u polish wheels? (Martingtrco)
Strip the paint off, then start sanding for hours going from coarse and end with a fine grit. Apply polish to it.
Old Jun 9, 2005 | 10:10 AM
Redwidow's Avatar
Default Re: how do u polish wheels? (chowmien)
not sure if you have aluminum wheels or painted, as the article says"But first, if they are magnesium alloy (mag alloy) you can forget the polishing bit unless they contain less than 20% magnesium. I don't care what any other polish manufacturer tells you. Magnesium is white and will not polish. If anyone tells you they have a mag alloy polish, it's an aluminum polish. Your mag wheels will come clean with a wash, and if you have used an acid or they are oxidizing you can clean them and remove the oxides with polishes, but magnesium doesn't shine."
...heres the article telling you step by step how to...so have fun and oh it is pretty dam hard to do wheels if you do not have all the proper tools...you may check with some local metal shops and they maybe able to do it for a good price..unless your the do it your self kinda perosn...have fun!
http://www.englishcustompolish....html
Old Jun 9, 2005 | 04:41 PM
92BluEH-3's Avatar
lulz
if they are aluminum or chrome get some mothers polish and then they will shine like new bling
Old Jun 10, 2005 | 03:17 PM
solareclipseauto's Avatar
Default Re: (92'BluV-tecHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92’BluV-tecHatch &raquo;</TD></TR><TR><TD CLASS="quote">if they are aluminum or chrome get some mothers polish and then they will shine like new bling</TD></TR></TABLE>
use a polish called neverdull, its a wadding polish. all you do is pull some out and polish the rim and wipe off
Old Aug 2, 2005 | 10:33 AM
bigkshep's Avatar
you guys think it would be hard to do if i had flat black slipstreams? I would rather have polished slips instead.
Old Aug 4, 2005 | 12:45 PM
Keith P's Avatar
Default Re: (bigkshep)
Step 1, remove powdercoat...
I'm still stuck on step 1
Here is my thread (not to jack this one or anything) trying to figure that much out:
https://honda-tech.com/zerothread?id=1329452
And polishing is much easier with the right tools.
I used an 8" buffing wheel on my drill with the proper cutting paste. Saved HOURS.
The Recession
Oct 9, 2008 10:25 AM
The Recession
Oct 1, 2008 09:48 PM
Singlecam4dr
May 2, 2007 04:30 PM
ravenracer
May 31, 2006 08:58 AM
cbr600jefF2
Honda Motorcycles
Apr 29, 2003 07:16 PM
